Flashing over Cobb Tune
Postby bmw5002 » Tue Jul 22, 2008 10:42 am
Hey guys, my friend picked up a used 05 wrx from a dealership and i have reason to believe it has an accessport map that was not unmarried. Will I be able to reflash over the cobb map successfully if the AP was not unmarried?
bmw5002
Postby radsdau » Tue Jul 22, 2008 5:15 pm
If it was married and had no security enabled (unlocked), then reflash straight over.
If it had security enabled as well (i.e., locked) then you have 3 options:
1. Find the original AccessPort and unmarry it
2. Coerce a kind Cobb dealer to unlock it for you (I think this is possible? May require a carton of beer)
3. Use one of the ECU repair services advertised around on this forum to background-reflash the original ROM back in. This is not ideal because it means you have to reflash with ECU out and send it to someone, and there will be a married AccessPort out there somewhere that can't be used on another vehicle.
Users browsing this forum: No registered users and 45 guests
