tables all messed up...
Postby perkki » Thu Jun 19, 2008 1:35 pm
I purchased a tactrix cable and tryed to connect to ecu with ecuflash 1.34 - no luck. Finally cot connected with ecuflash 1.29 but all the tables are messed up. Is there any solution?
perkki
Postby todd-w » Thu Jun 19, 2008 2:39 pm
wrong definition file what rom is it
todd-w
Postby perkki » Fri Jun 20, 2008 3:48 am
forester sti
ECU ID: 3B02594006
Internal ID: A2WC000E
Memory model: SH7055
perkki
Postby merchgod » Sat Jun 21, 2008 4:21 am
sounds like you're using newer definitions with an older version of ecuflash - this will not work unless you change the endian attribute in the bases from "little" to "big"
merchgod
