I had ecuflash 1.3 and t worked perfectly until i updated to the newest.
now, i cannot read nor can i write. the car just goes into test mode and ecu flash will not connect.
the test mode connectors ARE connected.
I followed EVERY step in removing the old version and all associated drivers.
I installed the driver that comes with ecu flash and no other driver.
i am about to kill myself this is so frustrating, please someone help me out
[21:46:47.250] Version 1.35.1650
[21:46:47.265] 11 memory models read.
[21:46:47.265] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[21:46:47.406] 250 ROM metadata models scanned.
[21:46:47.406] checksum module "subarudbw" loaded.
[21:46:47.406] flashing tool "wrx02" loaded.
[21:46:47.406] flashing tool "wrx04" loaded.
[21:46:47.406] flashing tool "sti04" loaded.
[21:46:47.406] flashing tool "sti05" loaded.
[21:46:47.406] flashing tool "mitsukernel" loaded.
[21:46:47.406] flashing tool "mitsukernelocp" loaded.
[21:46:47.406] flashing tool "shbootmode" loaded.
[21:46:51.375] A4SGD10C (299 tables) inheriting 16BITBASE (423 tables)
[21:46:51.390] A4SGE01C (6 tables) inheriting A4SGD10C (426 tables)
[21:46:51.421] 163840 byte image read.
[21:47:02.718] Using interface OpenPort 1.3 Universal TX45rBeW9318b7c95cd3cdc8095595debdd5607b69903b04
[21:47:05.593] denso02_bootloader_cmd_start
[21:47:06.812] denso02_bootloader_cmd_start
[21:47:08.031] denso02_bootloader_cmd_start
[21:47:09.250] denso02_bootloader_cmd_start
[21:47:10.468] denso02_bootloader_cmd_start
[21:47:10.906] kernel get version
[21:47:11.234] interface close
