Ok i connect my OBD II cable to try clear a CEL light, I connected the 2 green plugs together under the dash and turned the ingnition on, i have the reflash jumpers but couldnt see anywhere to connect it, i have looked at scoobypedia for what to look for but couldnt see anything the CEL light started to flash and the coolant fans for the radiator started to spin up then shut of continously, i tried connecting to ecu explorer but nothing would happen, it cant see the ecu, i have a wrx UK 05 blobeye when i connected the cable it came up its running version 1.3 is this right for this car or should it be 1.2?
any help would be great.
