Write problems ECU EDM STI03
Postby Fred » Sat Mar 08, 2008 1:57 pm
Hello haver if someone can help me. :( :(
I read an STI ECU 03 EDM but I will not let me write in the new map ECU
The mistake is giving me this
[00:11:34.734] Version 1.29.906
[00:11:34.734] 8 memory models read.
[00:11:36.015] 144 ROM metadata models read.
[00:11:36.015] checksum module "subarudbw" loaded.
[00:11:36.015] flashing tool "wrx02" loaded.
[00:11:36.015] flashing tool "wrx04" loaded.
[00:11:36.015] flashing tool "sti04" loaded.
[00:11:36.015] flashing tool "sti05" loaded.
[00:11:36.015] flashing tool "mitsukernel" loaded.
[00:11:36.015] flashing tool "mitsukernelocp" loaded.
[00:11:36.015] flashing tool "mitsubootloader" loaded.
[00:11:44.656] 163840 byte image read.
[00:11:47.109] Flashing tools do not recognize flash method ''
[00:11:48.968] Flashing tools do not recognize flash method ''
[00:11:50.671] Flashing tools do not recognize flash method ''
[00:11:58.265] Flashing tools do not recognize flash method ''
[00:11:59.625] Flashing tools do not recognize flash method ''
[00:12:01.312] Flashing tools do not recognize flash method ''
[00:12:02.906] Flashing tools do not recognize flash method ''
[00:12:04.812] Flashing tools do not recognize flash method ''
[00:12:05.500] Flashing tools do not recognize flash method ''
[00:12:06.203] Flashing tools do not recognize flash method ''
[00:12:06.906] Flashing tools do not recognize flash method ''
[00:12:07.359] Flashing tools do not recognize flash method ''
Fred
Postby NeverLies » Sun Mar 09, 2008 7:58 am
You should edit the corresponding xml scheme and fill the flashing method attribute ;)
Postby FrSTi » Sun Mar 09, 2008 10:38 am
NeverLies wrote:You should edit the corresponding xml scheme and fill the flashing method attribute ;)
Spot on ! ;)
FrSTi
Postby Fred » Sun Mar 09, 2008 10:47 am
Spot on ! ;)
I do not quite understand that you mean :cry: , I tried to write to ECU map serial nor leaves me
Sorry for my English but I am Spanish and translate with software :? :?
Fred
Postby NeverLies » Sun Mar 09, 2008 11:49 am
Browse to your installation folder, should be : "C:\Program Files\OpenECU\EcuFlash\rommetadata\subaru"
Base on your ecuID (should be A4RN200H it you do not have a bugeye), edit the corresponding xml file.
Look for string like this one : "<flashmethod></flashmethod>"
and replace it by " <flashmethod>wrx02</flashmethod>"
then restart OpenECU and enjoy your mapping !
Postby Fred » Sun Mar 09, 2008 1:36 pm
NeverLies wrote:Browse to your installation folder, should be : "C:\Program Files\OpenECU\EcuFlash\rommetadata\subaru"
Ok :D :D :D now if I understood it, I will do so thank you :wink: :wink:
Fred
