EGT sensor remove and disabled
Postby bouboule » Fri Jan 11, 2008 2:48 am
Hello, i need help about the remove of this sensor with ecuflash or enginuity.
I want to remove the sensor in up-pipe and after remove it for the ecu doesn't take egt information.
But how can i make this operation?
Thanks for your answer.:wink:
Sorry for the bad english!!
bouboule
Postby snikkels » Fri Jan 11, 2008 11:23 am
Hello, You can set it off whit ecuflash.
are you from NL??
snikkels
Postby bouboule » Sat Jan 12, 2008 3:28 am
ok but how, i don't find the table in ecuflash.. Please help me..
No i'm french :wink:
bouboule
Postby snikkels » Sun Jan 13, 2008 9:46 am
You must disable DTC (P0546)
snikkels
Postby bouboule » Tue Jan 15, 2008 8:00 am
ok but this disable only the Check Engine for this sensor default. After that can i remove it from exhaust? Ecu can't like this operation? Thanks..
PS: I've look for other map like WRX01 USDM, anbd they have in section MISC a table with the EGT sensor scaling. With that i can remove easily the value. I've search but i don't find the adress for this table to add it in my XML file. (with Enginuity, i've the same problem..) :?
bouboule
Users browsing this forum: No registered users and 52 guests
