Using ecuflash for both evo's and Sti's
Postby got boost? » Fri Nov 16, 2007 12:38 pm
I've always used ecuflash V1.3 for tuning evo's and zero problem, but yesterday i read an MY06 EDM STI, saved the rom and then modified the rev limiter to 7500 (7000 Stock), wrote to ECU with no problem but when we did a road test nothing happened, rev limiter is still in 7000. So i installed ecuflash 1.34 and worked fine, but now when i try to read an already saved Evo rom, stationay rev limiter shows "2" !!!!!!!! and all the parameters show weird things.
Please i need some help with this, i need to be able to flash both cars.
Now i installed V1.3 again and worked fine with the evo rom, but wrong with sti's.
Thanks guys.!
got boost?
Postby Freon » Sat Nov 17, 2007 10:41 am
Drive by wire closes the throttle body at red line on most cars. You need to modify the throttle tables as well to raise the rev limit.
Users browsing this forum: No registered users and 27 guests
