inherited the wrong ID and can't change it
Postby Mellon » Wed Oct 24, 2007 4:52 pm
surely there's an easy fix to this.
I have a ROM that's for an 88840013 and in hind sight I've learned that I have to inherit 888400016 to view it properly. The problem is that I've already inherited something else and now it doesn't prompt me to choose anymore.
what's the trick to fixing this issue. I need to get it to inherit the right one now that I know which one it should be using.
I did some searching and haven't seen a post about his problem. I did a separate install of ecuflash and that works but I need to fix my main install.
Mellon
Postby radsdau » Wed Oct 24, 2007 10:06 pm
You should be able to fix this by manually editing the XML files. The 'inherits' tag is easy to find in there.
Postby Mellon » Thu Oct 25, 2007 1:43 pm
ok, so when you inherit it modifies the xml for 88840013? that's the file I should change right?
Mellon
