ECU Flash error
ECU Flash error
Postby zigzagzok » Tue Oct 23, 2007 12:12 am
need help - can someone take a look at below?thks
[14:10:25.356] Version 1.33.1426
[14:10:25.356] 11 memory models read.
[14:10:25.356] scanning for metadata models in D:/Program Files/OpenECU/EcuFlash/rommetadata
[14:10:25.466] 219 ROM metadata models scanned.
[14:10:25.466] checksum module "subarudbw" loaded.
[14:10:25.466] flashing tool "wrx02" loaded.
[14:10:25.466] flashing tool "wrx04" loaded.
[14:10:25.466] flashing tool "sti04" loaded.
[14:10:25.466] flashing tool "sti05" loaded.
[14:10:25.466] flashing tool "mitsukernel" loaded.
[14:10:25.466] flashing tool "mitsukernelocp" loaded.
[14:10:25.466] flashing tool "shbootmode" loaded.
[14:10:52.094] Using interface OpenPort 1.3 Mitsubishi TX34SgeH8c50f6c94845ed4dd0ed9738468961236c930ff5
[14:10:58.854] SSM2 init
[14:10:59.134] SSM2 ECU ID is 4B 04 78 50 07
[14:11:01.207] interface close
[14:11:01.227] interface close
[14:11:18.642] Using interface OpenPort 1.3 Mitsubishi TX34SgeH8c50f6c94845ed4dd0ed9738468961236c930ff5
[14:11:24.721] SSM2 init
[14:11:25.001] SSM2 ECU ID is 4B 04 78 50 07
[14:11:27.064] interface close
[14:11:27.074] interface close
[14:11:49.336] Using interface OpenPort 1.3 Mitsubishi TX34SgeH8c50f6c94845ed4dd0ed9738468961236c930ff5
[14:11:53.633] SSM2 init
[14:11:53.913] SSM2 ECU ID is 4B 04 78 50 07
[14:11:53.913] SSM2 read ram byte addr: 000061
[14:11:54.003] ECU is in test mode
[14:11:54.073] SSM2 init
[14:11:54.344] SSM2 ECU ID is 4B 04 78 50 07
[14:11:56.396] interface close
[14:11:56.406] interface close
zigzagzok
Postby radsdau » Tue Oct 23, 2007 3:55 pm
Sounds like the wrong flash method, or an unsupported ECU; it's not a late model (07) Forester or STi per chance?
