Impossible to connect with ecuflahs
Postby Fred » Mon Oct 08, 2007 1:34 pm
Hello, I can help someone
:cry: :cry: impossible to connect with ecuflahs in EVO EDM 7.8.9 and subaru to me STI EDM 03 I have proven with versions 1.29,1,30,1,31 and he is to me imposle to connect tb to me I have proven with different versions from XP
single I have been able in WRX EDM 2001 2002
the cable is the version for subaru and evo
I make all the steps to connect themselves but it does not leave me
of where can vnir my problem, of the cable? of the program? of the XP? of my?
The 03 STI I connect with ecuedit to seamlessly log
to pardon to me if my English is not good :? :cry:
Fred
Re: Impossible to connect with ecuflahs
Postby Fred » Wed Oct 17, 2007 12:11 pm
Hello, anybody can help me? ?
This is what I get when I try to connect to a evo 8 with ecuflahs 1.29 to 1.33 and :cry: :cry:
1,29a
sending init sequence 1 (0001)
sending init sequence 1 (0003)
sending init sequence 1 (FFFF)
no response to any known code
1.33
using interface openport 1,3 universal
TX25IvNj8487f6c9235423d5075f5b6d81d874ea179212ec
interface close
interface close
Fred
Postby radsdau » Wed Oct 17, 2007 3:12 pm
Make sure the programming voltage connector is connected when hooking up with EVOs, otherwise it will not work. Also check ignition is on to correct setting ("ON").
If you still get no response, the ECU might be locked.
Postby Jeff_Jeske » Fri Oct 19, 2007 11:31 am
This happens to me when the car has been sitting and is cold. If I start the car and go for a 5 minute drive then try to flash it it works like a champ.
It should be noted that my EVOScan works just fine when the car is cold but the ECU will not allow a flash and reports: no response to any known code
I have an EVO9 SE with 15 rom.
Jeff_Jeske
Postby Fred » Fri Oct 19, 2007 1:38 pm
If the socket is well placed in position and contact "ON"
I tried everything I put up a version of XP in English and nothing (I am from spain) :oops: :oops:
At the end I asked another cable to 1.3 M Cboles "Tactrix" :roll:
Haver if it works well
Thanks to all
Freed
Fred
Postby nscreations » Sun Oct 21, 2007 3:40 pm
is there any updates on thie im getting the same error tried 1.28 1.29 and 1.33 and still give me the same errors. anyhelp would be greatful
nscreations
Users browsing this forum: Google [Bot] and 39 guests
