Need to adjust the TPS value for EGR (evo8)
Postby C6ect.ect » Tue Oct 02, 2007 5:59 pm
What are the possibilities having EGR tables in future ecuflash versions?
I really need to adjust the TPS value for EGR control in my car real bad. The throttle response with the car's current setup loads the engine before the EGR has a chance to close pneumatically. So exhaust gas is still recirculating at part throttle heating things up and causing knock before it has a chance to close. If I could just set the TPS value lower with EGR contol then the solenoid would energize faster stopping recirc before things get hot. This only happens at part throttle when the system normally (OEM) starts to shut down.
Any info on this topic as a parameter yet?
Also for those of you involved, thanks for ECUFLASH in the first place!
C6ect.ect
Postby C6ect.ect » Wed Oct 03, 2007 8:10 am
Factors that determine EGR solenoid duty include TPS, MAF, coolant temp, and RPM :P
C6ect.ect
Postby gteclass » Thu Oct 04, 2007 4:57 am
what car is this for?
what model ecu?
gteclass
Postby C6ect.ect » Thu Oct 04, 2007 3:26 pm
2004 USDM EVOVIII
SH7052
ROM ID: 96420007
Mitsukernel
C6ect.ect
Postby gteclass » Fri Oct 05, 2007 9:12 am
if you apply for an aktivematrix.com account, there are people there who can better help you with this.
gteclass
Postby C6ect.ect » Sat Oct 06, 2007 7:57 pm
I am beginning to believe many of the BE tables belong to the EGR system - 95% sure. Colby?
C6ect.ect
