12.40v is till too low???
Postby monaka » Sun Aug 26, 2007 6:19 pm
Yes, I read topic "12.56v is till tool low???".
And I've encounterd similar issue.
[01:54:18.000] reading ecu programming voltage
[01:54:18.015] programming voltage is 12.40 volts
[01:54:18.015] kernel flash enable
[01:54:18.031] kernel blank flash page: addr: 00028000
[01:54:18.046] kernel error: programming voltage is too low
[01:54:18.046] WARNING: failed to erase page at 00028000!
Then, I have some questions.
Cboles said to fix "low" to "out of range" but there seems not to fixed yet.
Is it true? The version of ecuflash is 1.30.1095 ... maybe newest stable version.
I want to know the voltage range that the kernel allows. I think 12.4V is not out of range for flash devices.
Thanks,
monaka
Postby monaka » Sun Aug 26, 2007 9:59 pm
I found a hint by reading code in hc16subaru.rar.
; CONSTANTS
min_programming_voltage:      equ   570 ; (11.4V * 50/V)
max_programming_voltage:   equ 630 ; (12.6V * 50/V)
Are these constants used by the current version?
monaka
