XP BSOD Kernel Problem???
Postby MR-EVO » Wed Aug 15, 2007 5:09 am
Ok so 1.29 use to work perfectly on my laptop.
Then I had a Blue screen problem and eventually managed to fix my corrupt registry and now everything else except ECU Flash works...
Loaded XP sp2 somewhere along the line...
It keeps failing with what seems to be an application error due to some kind of violation.
Anyone else have this problem?
Gona try and do a recovery with the XP Pro system Disk and see if this fixes the problem.
MR-EVO
Postby MR-EVO » Tue Sep 25, 2007 5:37 am
So after much messing around and reloading Windows I finally found the problem...
Your not gona believe this the cause was actual an XML file in the ROMETADATA:
88840013.xml
:shock:
MR-EVO
