Problem flashing 04 sti euro
Postby Dave Harries » Tue Jun 19, 2007 11:37 pm
I have now been able to pull the rom from the ecu . I have modified it and am trying to put it back in , the cable is a 1.3 universal and ecuflash 1.3 when trying to flash I get the message
Flashing tools do not recognize flash method ''
I have the green connectors connected and the white flash block in place , what could be wrong?
Any help greatfully accepted Dave
Dave Harries
Postby Freon » Wed Jun 20, 2007 7:41 am
There is something wrong with the flash method in the XML for whatever ROM you are using.
What is the CAL ID for your ECU? (something like A2ZS710J) Go to the /ecuflash/rommetadata directory and find the XML file for that ID, open it in notepad, or just post the whole XML file.
Postby Dave Harries » Wed Jun 20, 2007 9:04 am
Case ID: AH992-5513
Internal ID: A4RN200H
ECU and Flash method are blank
- <rom>
- <romid>
<xmlid>A4RN200H</xmlid>
<internalidaddress>200</internalidaddress>
<internalidstring>A4RN200H</internalidstring>
<caseid>AH992-5513</caseid>
<ecuid />
<make>Subaru</make>
<market>EDM</market>
<model>Impreza</model>
<submodel>WRX STi</submodel>
<transmission>Manual/Auto</transmission>
<year>2003/2004</year>
<flashmethod />
<memmodel>68HC16Y5</memmodel>
</romid>
<include>wrxbase</include>
- <table name="Target Boost (MT)" address="2b6d9">
<table name="X" address="2b6cf" scaling="Throttle2" />
<table name="Y" address="2b6bc" />
</table>
- <table name="Target Boost (AT)" address="2b6b8">
<table name="X" address="2b6b4" elements="2" scaling="Throttle2" />
<table name="Y" address="2b6af" elements="2" />
</table>
<table name="Boost Limit (CEL)" address="2bcc9" />
<table name="Boost Limit (Fuel Cut)" address="29943" />
<table name="Boost Compensation by Gear (MT)" address="2b83c" />
<table name="Boost Compensation by Gear (AT)" address="2b841" />
- <table name="Initial Wastegate Duty" address="2b8ad" scaling="WGDuty16">
<table name="X" address="2b8a3" scaling="Throttle2" />
<table name="Y" address="2b892" />
</table>
- <table name="Max Wastegate Duty" address="2b768" scaling="WGDuty16">
<table name="X" address="2b75e" scaling="Throttle2" />
<table name="Y" address="2b74d" />
</table>
- <table name="Turbo Dynamics (Integral Positive)" address="2b880">
<table name="Y" address="2b86c" />
</table>
- <table name="Turbo Dynamics (Integral Negative)" address="2b85a">
<table name="Y" address="2b846" />
</table>
- <table name="Turbo Dynamics (Proportional Gain)" address="2b735">
<table name="Y" address="2b721" />
</table>
<table name="Wastegate Compensation (Atmosphere)" address="2b7ee" />
<table name="Wastegate Compensation (Intake Temp)" address="2b7f8" />
- <table name="Low Detonation Fuel" address="2936f">
<table name="X" address="2934d" elements="16" />
<table name="Y" address="29328" elements="18" />
</table>
- <table name="High Detonation Fuel" address="2963d">
<table name="X" address="2961b" elements="16" />
<table name="Y" address="295f6" elements="18" />
</table>
<table name="Injector Latency" address="289b6" />
<table name="Injector Flow Scaling" address="289ae" />
- <table name="Fuel Enrichment (Throttle)" address="297e8">
<table name="Y" address="297d4" />
</table>
- <table name="Base Ignition Timing" address="29c20">
<table name="X" address="29bfe" elements="16" />
<table name="Y" address="29bd9" elements="18" />
</table>
- <table name="Ignition Correction" address="2a1e0">
<table name="X" address="2a1be" elements="16" />
<table name="Y" address="2a199" elements="18" />
</table>
- <table name="Intake Cam Advance Angle (AVCS)" address="2b1d7">
<table name="X" address="2b1b9" />
<table name="Y" address="2b190" elements="20" />
</table>
<table name="Advance Multiplier (Initial)" address="2a300" />
<table name="Advance Multiplier (Boost Control)" address="2b82e" />
<table name="Advance Multiplier (Fuel Map Switch)" address="291bf" />
<table name="Knock Detection Range (RPM)" address="2a33b" />
<table name="Knock Detection Minimum (Load)" address="2a343" />
<table name="Rough Correction Range (RPM)" address="2a301" />
<table name="Rough Correction Range (Load)" address="2a309" />
<table name="Fine Correction Range (RPM)" address="2a383" />
<table name="Fine Correction Range (Load)" address="2a38b" />
<table name="Fine Correction Rows (RPM)" address="2a358" />
<table name="Fine Correction Columns (Load)" address="2a348" />
- <table name="MAF Sensor Scaling" address="2808a">
<table name="Y" address="28028" />
</table>
<table name="MAF Sensor Limit (CEL)" address="2bb68" />
<table name="Rev Limit" address="29912" />
<table name="Speed Limiting (Fuel Cut)" address="29933" />
<table name="Min Idle Speed A/C (MT)" address="2a766" />
<table name="Min Idle Speed A/C (AT)" address="2a768" />
<table name="Min Idle Speed Startup (MT)" address="2a9cb" />
<table name="Min Idle Speed Startup (AT)" address="2a9c3" />
<table name="Closed Loop EGT" address="29137" />
<table name="Closed Loop RPM" address="29129" />
<table name="Closed Loop Delays" address="2913f" />
<table name="Closed Loop Vehicle Speed" address="29135" />
<table name="Closed Loop Calculated Load" address="2917f" />
<table name="Closed Loop Min Coolant Temp" address="29127" />
<table name="Closed Loop Throttle (Primary)" address="29169" />
<table name="Closed Loop Throttle (Sea Level)" address="2912f" />
<table name="Closed Loop Throttle (High Altitude)" address="2912d" />
<table name="Closed Loop Atmospheric Pressure" address="2915f" />
<table name="DTC P0037" address="2D6B5" />
<table name="DTC P0038" address="2D6AD" />
<table name="DTC P0137" address="2D679" />
<table name="DTC P0138" address="2D691" />
<table name="DTC P0139" address="2D5F1" />
<table name="DTC P0420" address="2D60D" />
<table name="DTC P0545" address="2D7E1" />
<table name="DTC P0546" address="2D7E5" />
<table name="DTC P1301" address="2D649" />
<table name="DTC P1312" address="2D7E9" />
<table name="DTC P1544" address="2D7ED" />
<table name="Cat Efficiency B" address="2B9F7" />
<table name="Cat Efficiency C" address="2BA0D" />
</rom>
Thanks very much for the reply Dave
Dave Harries
Postby merchgod » Wed Jun 20, 2007 1:07 pm
change the flashmethod tag to read:
<flashmethod>wrx02</flashmethod>
merchgod
Postby Dave Harries » Wed Jun 20, 2007 1:23 pm
Merchgod thanks very much , all of the euro STi roms I down loaded non have a flash method assigned to them , is this normal?
Thanks again Dave
Dave Harries
Postby FrSTi » Wed Jun 20, 2007 2:00 pm
Dave Harries wrote:Merchgod thanks very much , all of the euro STi roms I down loaded non have a flash method assigned to them , is this normal?
Thanks again Dave
All MY01 to MY05 EDM STi (2.0 Non-TS AVCS) must use the following tag :
FrSTi
