STi 04 edm reading problems
Postby Dave Harries » Mon Jun 18, 2007 3:34 am
Right then I've just got my 1.3 universal cable and I'm still having trouble connecting to the ecu to read it , I get this come up on the screen
[20:56:59.328] Version 1.30.1095
[20:56:59.343] 8 memory models read.
[20:57:01.281] 145 ROM metadata models read.
[20:57:01.281] checksum module "subarudbw" loaded.
[20:57:01.281] flashing tool "wrx02" loaded.
[20:57:01.281] flashing tool "wrx04" loaded.
[20:57:01.281] flashing tool "sti04" loaded.
[20:57:01.296] flashing tool "sti05" loaded.
[20:57:01.296] flashing tool "mitsukernel" loaded.
[20:57:01.296] flashing tool "mitsukernelocp" loaded.
[20:57:01.296] flashing tool "mitsubootloader" loaded.
[20:58:03.875] denso02_bootloader_cmd_start
[20:58:05.265] denso02_bootloader_cmd_start
[20:58:06.656] denso02_bootloader_cmd_start
[20:58:08.046] denso02_bootloader_cmd_start
[20:58:09.437] denso02_bootloader_cmd_start
[20:58:10.046] kernel get version
any help would be appreciated
Cheers Dave
Dave Harries
Postby Dave Harries » Mon Jun 18, 2007 8:38 am
Ok update can read the ecu now , but can't flash
Dave Harries
Postby Jon [in CT] » Mon Jun 18, 2007 1:09 pm
Is your flash connector (see pic) connected to the flash block?
Postby Dave Harries » Mon Jun 18, 2007 1:30 pm
Yes I have the connector in , but the screen says that the flash method is not supported ( or something similar )
Dave Harries
Postby Dave Harries » Mon Jun 18, 2007 1:32 pm
Oh and when I try to flash using ecuexplorer, it says that it can't read the programming voltage
Dave Harries
Postby Jon [in CT] » Mon Jun 18, 2007 2:43 pm
The flash method should be related to wrx04 (not sti04).
What program did you use to read your ROM from the ECU? Have you actually changed anything in it?
Postby Dave Harries » Mon Jun 18, 2007 3:11 pm
I used ecuflash to pull the rom modified it in enginuity and then tried to flash back using ecuflash .
In ecuexplorer I got the message that it couldn't read the programming voltage and in ecuflash it said that the flashing method was not supported
Dave Harries
Postby FrSTi » Wed Jun 20, 2007 2:03 pm
All MY01 to MY05 EDM STi (2.0 Non-TS AVCS) must use the following tag in ecuflash :
<flashmethod>wrx02</flashmethod>
FrSTi
Postby korhan » Thu Jun 21, 2007 4:32 am
in hex file change the method to wrxbase.
in program files find the rommetadata,subaru and the A4RN200H. change the flashing method to wrxbase or wrx02base. copy it to the wrx rommerdate files. it will like the below.....
- <rom>
- <romid>
<xmlid>A4RN200H</xmlid>
<internalidaddress>200</internalidaddress>
<internalidstring>A4RN200H</internalidstring>
<caseid>AH992-5513</caseid>
<ecuid />
<make>Subaru</make>
<market>EDM</market>
<model>Impreza</model>
<submodel>WRX STi</submodel>
<transmission>Manual/Auto</transmission>
<year>2003/2004</year>
<flashmethod />
<memmodel>68HC16Y5</memmodel>
</romid>
<include>wrxbase</include>
korhan
Postby Dave Harries » Thu Jun 21, 2007 7:47 pm
all sorted now thanks :D :D
Dave Harries
Postby MARC CANTWELL » Tue Jul 03, 2007 8:38 am
Jon [in CT] wrote:Is your flash connector (see pic) connected to the flash block?
ok i have a 05 sti and i have both the connectors but i get a read error when i try to read my ecu with ecuflash? i thought the sti did not need anything to connect? i can log my car using enginuity but when i try to read my ecu it comes up rear error review log?
MARC CANTWELL
Postby Dave Harries » Tue Jul 03, 2007 2:24 pm
The main problem I had was I was supplied with the wrong cable . I initially had the 1.3M and after recieving the 1.3U I was able to upload and download to the ecu . Which cable do you have?
Dave Harries
Postby korhan » Fri Jul 06, 2007 11:21 pm
for 2005 sti, you have to connect te green test connectors and also the white flashing connector to read and write the map:)
you have to use sti05 flashing method.
korhan
Users browsing this forum: No registered users and 56 guests
