Flash failure
Flash failure
Postby Blindstuff » Mon May 21, 2007 6:45 pm
My car died half flash. Here is the log? Im still with the car on, I dont dare turn it off, what should I do?
[03:32:12.240] Version 1.30.1095
[03:32:12.240] 8 memory models read.
[03:32:13.363] 147 ROM metadata models read.
[03:32:13.363] checksum module "subarudbw" loaded.
[03:32:13.363] flashing tool "wrx02" loaded.
[03:32:13.363] flashing tool "wrx04" loaded.
[03:32:13.363] flashing tool "sti04" loaded.
[03:32:13.363] flashing tool "sti05" loaded.
[03:32:13.363] flashing tool "mitsukernel" loaded.
[03:32:13.363] flashing tool "mitsukernelocp" loaded.
[03:32:13.363] flashing tool "mitsubootloader" loaded.
[03:32:23.706] 196608 byte image read.
[03:32:28.776] denso02_bootloader_cmd_start
[03:32:29.010] writing kernel area addr: 020000 len: 063C
[03:32:30.928] kernel get version
[03:32:30.960] kernel version is : OpenECU Subaru HC16 Kernel V1.03
[03:32:30.960] reading kernel comm buffer size
[03:32:30.975] comm buffer size set to 512
[03:32:30.975] reading kernel flash buffer size
[03:32:30.991] flash buffer size set to 4096
[03:32:30.991] Flashing image to ECU memory...
[03:32:31.396] comparing ECU flash memory pages to image file
[03:32:31.396] segment len ecu CRC32 img CRC32 same?
[03:32:31.740] FB01 00004000 F8FF475D F8FF475D YES
[03:32:32.067] FB02 00004000 2D447BD0 2D447BD0 YES
[03:32:32.410] FB03 00004000 AC08E666 AC08E666 YES
[03:32:32.738] FB04 00004000 F1E88506 F1E88506 YES
[03:32:33.081] FB05 00004000 F827A198 F827A198 YES
[03:32:33.409] FB06 00004000 1D2DE901 1D2DE901 YES
[03:32:33.752] FB07 00004000 24B1156C 24B1156C YES
[03:32:34.080] FB08 00004000 7259CC9A 7259CC9A YES
[03:32:34.423] FB09 00004000 0E03A941 CF538AB9 NO
[03:32:34.750] FB10 00004000 142BDE67 142BDE67 YES
[03:32:35.062] reading ecu programming voltage
[03:32:35.094] programming voltage is 12.11 volts
[03:32:35.094] kernel flash enable
[03:32:35.109] kernel blank flash page: addr: 00028000
[03:32:35.125] kernel error: programming voltage is too low
[03:32:35.125] WARNING: failed to erase page at 00028000!
[03:32:35.125] kernel write flash buffer addr: 00028000 len: 00000200
[03:32:35.281] kernel write flash buffer addr: 00028200 len: 00000200
[03:32:35.437] kernel write flash buffer addr: 00028400 len: 00000200
[03:32:35.593] kernel write flash buffer addr: 00028600 len: 00000200
[03:32:35.749] kernel write flash buffer addr: 00028800 len: 00000200
[03:32:35.905] kernel write flash buffer addr: 00028A00 len: 00000200
[03:32:36.061] kernel write flash buffer addr: 00028C00 len: 00000200
[03:32:36.217] kernel write flash buffer addr: 00028E00 len: 00000200
[03:32:36.373] kernel commit flash addr: 00028000 crc32 7e228431
[03:32:36.466] kernel error: programming voltage is too low
[03:32:36.466] failed to commit flash at 00028000!
[03:32:36.466] WARNING: failure in flashing block
[03:32:36.466] kernel write flash buffer addr: 00029000 len: 00000200
[03:32:36.622] kernel write flash buffer addr: 00029200 len: 00000200
[03:32:36.778] kernel write flash buffer addr: 00029400 len: 00000200
[03:32:36.934] kernel write flash buffer addr: 00029600 len: 00000200
[03:32:37.090] kernel write flash buffer addr: 00029800 len: 00000200
[03:32:37.246] kernel write flash buffer addr: 00029A00 len: 00000200
[03:32:37.402] kernel write flash buffer addr: 00029C00 len: 00000200
[03:32:37.558] kernel write flash buffer addr: 00029E00 len: 00000200
[03:32:37.714] kernel commit flash addr: 00029000 crc32 f90cac2d
[03:32:37.808] kernel error: programming voltage is too low
[03:32:37.808] failed to commit flash at 00029000!
[03:32:37.808] WARNING: failure in flashing block
[03:32:37.808] kernel write flash buffer addr: 0002A000 len: 00000200
[03:32:37.964] kernel write flash buffer addr: 0002A200 len: 00000200
[03:32:38.120] kernel write flash buffer addr: 0002A400 len: 00000200
[03:32:38.276] kernel write flash buffer addr: 0002A600 len: 00000200
[03:32:38.432] kernel write flash buffer addr: 0002A800 len: 00000200
[03:32:38.588] kernel write flash buffer addr: 0002AA00 len: 00000200
[03:32:38.744] kernel write flash buffer addr: 0002AC00 len: 00000200
[03:32:38.900] kernel write flash buffer addr: 0002AE00 len: 00000200
[03:32:39.056] kernel commit flash addr: 0002A000 crc32 0dbb592b
[03:32:39.150] kernel error: programming voltage is too low
[03:32:39.150] failed to commit flash at 0002A000!
[03:32:39.150] WARNING: failure in flashing block
[03:32:39.150] kernel write flash buffer addr: 0002B000 len: 00000200
[03:32:39.290] kernel write flash buffer addr: 0002B200 len: 00000200
[03:32:39.430] kernel write flash buffer addr: 0002B400 len: 00000200
[03:32:39.571] kernel write flash buffer addr: 0002B600 len: 00000200
[03:32:39.711] kernel write flash buffer addr: 0002B800 len: 00000200
[03:32:39.867] kernel write flash buffer addr: 0002BA00 len: 00000200
[03:32:40.023] kernel write flash buffer addr: 0002BC00 len: 00000200
[03:32:40.164] kernel write flash buffer addr: 0002BE00 len: 00000200
[03:32:40.320] kernel commit flash addr: 0002B000 crc32 ad13ed3a
[03:32:40.413] kernel error: programming voltage is too low
[03:32:40.413] failed to commit flash at 0002B000!
[03:32:40.413] WARNING: failure in flashing block
[03:32:40.413] kernel flash disable
[03:32:40.429] verifying result...
[03:32:40.429] comparing ECU flash memory pages to image file
[03:32:40.429] segment len ecu CRC32 img CRC32 same?
[03:32:40.772] FB01 00004000 F8FF475D F8FF475D YES
[03:32:41.115] FB02 00004000 2D447BD0 2D447BD0 YES
[03:32:41.443] FB03 00004000 AC08E666 AC08E666 YES
[03:32:41.786] FB04 00004000 F1E88506 F1E88506 YES
[03:32:42.114] FB05 00004000 F827A198 F827A198 YES
[03:32:42.457] FB06 00004000 1D2DE901 1D2DE901 YES
[03:32:42.784] FB07 00004000 24B1156C 24B1156C YES
[03:32:43.128] FB08 00004000 7259CC9A 7259CC9A YES
[03:32:43.455] FB09 00004000 0E03A941 CF538AB9 NO
[03:32:43.799] FB10 00004000 142BDE67 142BDE67 YES
[03:32:43.799] *** FLASH FAILURE ***
[03:33:05.857] denso02_bootloader_cmd_start
[03:33:07.261] denso02_bootloader_cmd_start
[03:33:08.665] denso02_bootloader_cmd_start
[03:33:10.069] denso02_bootloader_cmd_start
[03:33:11.473] denso02_bootloader_cmd_start
[03:33:12.081] kernel get version
[03:33:12.113] found oecu kernel!
[03:33:12.113] kernel already resident - skipping kernel load
[03:33:12.222] kernel get version
[03:33:12.253] kernel version is : OpenECU Subaru HC16 Kernel V1.03
[03:33:12.253] reading kernel comm buffer size
[03:33:12.269] comm buffer size set to 512
[03:33:12.269] reading kernel flash buffer size
[03:33:12.284] flash buffer size set to 4096
[03:33:12.284] Flashing image to ECU memory...
[03:33:12.690] comparing ECU flash memory pages to image file
[03:33:12.690] segment len ecu CRC32 img CRC32 same?
[03:33:13.017] FB01 00004000 F8FF475D F8FF475D YES
[03:33:13.345] FB02 00004000 2D447BD0 2D447BD0 YES
[03:33:13.673] FB03 00004000 AC08E666 AC08E666 YES
[03:33:14.000] FB04 00004000 F1E88506 F1E88506 YES
[03:33:14.328] FB05 00004000 F827A198 F827A198 YES
[03:33:14.656] FB06 00004000 1D2DE901 1D2DE901 YES
[03:33:14.983] FB07 00004000 24B1156C 24B1156C YES
[03:33:15.311] FB08 00004000 7259CC9A 7259CC9A YES
[03:33:15.654] FB09 00004000 0E03A941 CF538AB9 NO
[03:33:15.982] FB10 00004000 142BDE67 142BDE67 YES
[03:33:16.294] reading ecu programming voltage
[03:33:16.325] programming voltage is 4.43 volts
[03:33:16.325] programming voltage is out of range!
[03:34:03.063] denso02_bootloader_cmd_start
[03:34:04.467] denso02_bootloader_cmd_start
[03:34:05.871] denso02_bootloader_cmd_start
[03:34:07.275] denso02_bootloader_cmd_start
[03:34:08.679] denso02_bootloader_cmd_start
[03:34:09.287] kernel get version
[03:34:09.334] found oecu kernel!
[03:34:09.334] kernel already resident - skipping kernel load
[03:34:09.443] kernel get version
[03:34:09.474] kernel version is : OpenECU Subaru HC16 Kernel V1.03
[03:34:09.474] reading kernel comm buffer size
[03:34:09.490] comm buffer size set to 512
[03:34:09.490] reading kernel flash buffer size
[03:34:09.505] flash buffer size set to 4096
[03:34:09.505] Flashing image to ECU memory...
[03:34:09.911] comparing ECU flash memory pages to image file
[03:34:09.911] segment len ecu CRC32 img CRC32 same?
[03:34:10.239] FB01 00004000 F8FF475D F8FF475D YES
[03:34:10.582] FB02 00004000 2D447BD0 2D447BD0 YES
[03:34:10.909] FB03 00004000 AC08E666 AC08E666 YES
[03:34:11.237] FB04 00004000 F1E88506 F1E88506 YES
[03:34:11.565] FB05 00004000 F827A198 F827A198 YES
[03:34:11.892] FB06 00004000 1D2DE901 1D2DE901 YES
[03:34:12.220] FB07 00004000 24B1156C 24B1156C YES
[03:34:12.547] FB08 00004000 7259CC9A 7259CC9A YES
[03:34:12.891] FB09 00004000 0E03A941 CF538AB9 NO
[03:34:13.218] FB10 00004000 142BDE67 142BDE67 YES
[03:34:13.530] reading ecu programming voltage
[03:34:13.561] programming voltage is 5.27 volts
[03:34:13.561] programming voltage is out of range!
[03:36:03.386] denso02_bootloader_cmd_start
[03:36:04.790] denso02_bootloader_cmd_start
[03:36:06.194] denso02_bootloader_cmd_start
[03:36:07.598] denso02_bootloader_cmd_start
[03:36:09.002] denso02_bootloader_cmd_start
[03:36:09.611] kernel get version
[03:36:09.642] found oecu kernel!
[03:36:09.642] kernel already resident - skipping kernel load
[03:36:09.751] kernel get version
[03:36:09.782] kernel version is : OpenECU Subaru HC16 Kernel V1.03
[03:36:09.782] reading kernel comm buffer size
[03:36:09.798] comm buffer size set to 512
[03:36:09.798] reading kernel flash buffer size
[03:36:09.813] flash buffer size set to 4096
[03:36:09.813] Flashing image to ECU memory...
[03:36:10.219] comparing ECU flash memory pages to image file
[03:36:10.219] segment len ecu CRC32 img CRC32 same?
[03:36:10.547] FB01 00004000 F8FF475D F8FF475D YES
[03:36:10.874] FB02 00004000 2D447BD0 2D447BD0 YES
[03:36:11.202] FB03 00004000 AC08E666 AC08E666 YES
[03:36:11.529] FB04 00004000 F1E88506 F1E88506 YES
[03:36:11.857] FB05 00004000 F827A198 F827A198 YES
[03:36:12.185] FB06 00004000 1D2DE901 1D2DE901 YES
[03:36:12.528] FB07 00004000 24B1156C 24B1156C YES
[03:36:12.855] FB08 00004000 7259CC9A 7259CC9A YES
[03:36:13.199] FB09 00004000 0E03A941 CF538AB9 NO
[03:36:13.526] FB10 00004000 142BDE67 142BDE67 YES
[03:36:13.838] reading ecu programming voltage
[03:36:13.869] programming voltage is 6.09 volts
[03:36:13.869] programming voltage is out of range!
[03:38:48.732] denso02_bootloader_cmd_start
[03:38:50.136] denso02_bootloader_cmd_start
[03:38:51.540] denso02_bootloader_cmd_start
[03:38:52.944] denso02_bootloader_cmd_start
[03:38:54.348] denso02_bootloader_cmd_start
[03:38:54.956] kernel get version
[03:38:54.987] found oecu kernel!
[03:38:54.987] kernel already resident - skipping kernel load
[03:38:55.096] kernel get version
[03:38:55.128] kernel version is : OpenECU Subaru HC16 Kernel V1.03
[03:38:55.128] reading kernel comm buffer size
[03:38:55.143] comm buffer size set to 512
[03:38:55.143] reading kernel flash buffer size
[03:38:55.159] flash buffer size set to 4096
[03:38:55.159] Flashing image to ECU memory...
[03:38:55.564] comparing ECU flash memory pages to image file
[03:38:55.564] segment len ecu CRC32 img CRC32 same?
[03:38:55.892] FB01 00004000 F8FF475D F8FF475D YES
[03:38:56.235] FB02 00004000 2D447BD0 2D447BD0 YES
[03:38:56.563] FB03 00004000 AC08E666 AC08E666 YES
[03:38:56.890] FB04 00004000 F1E88506 F1E88506 YES
[03:38:57.218] FB05 00004000 F827A198 F827A198 YES
[03:38:57.546] FB06 00004000 1D2DE901 1D2DE901 YES
[03:38:57.873] FB07 00004000 24B1156C 24B1156C YES
[03:38:58.201] FB08 00004000 7259CC9A 7259CC9A YES
[03:38:58.544] FB09 00004000 0E03A941 CF538AB9 NO
[03:38:58.872] FB10 00004000 142BDE67 142BDE67 YES
[03:38:59.184] reading ecu programming voltage
[03:38:59.215] programming voltage is 6.25 volts
[03:38:59.215] programming voltage is out of range!
[03:39:50.258] denso02_bootloader_cmd_start
[03:39:51.662] denso02_bootloader_cmd_start
[03:39:53.066] denso02_bootloader_cmd_start
[03:39:54.470] denso02_bootloader_cmd_start
[03:39:55.874] denso02_bootloader_cmd_start
[03:39:56.483] kernel get version
[03:39:56.530] found oecu kernel!
[03:39:56.530] kernel already resident - skipping kernel load
[03:39:56.639] kernel get version
[03:39:56.670] kernel version is : OpenECU Subaru HC16 Kernel V1.03
[03:39:56.670] reading kernel comm buffer size
[03:39:56.686] comm buffer size set to 512
[03:39:56.686] reading kernel flash buffer size
[03:39:56.701] flash buffer size set to 4096
[03:39:56.701] Flashing image to ECU memory...
[03:39:57.107] comparing ECU flash memory pages to image file
[03:39:57.107] segment len ecu CRC32 img CRC32 same?
[03:39:57.434] FB01 00004000 F8FF475D F8FF475D YES
[03:39:57.762] FB02 00004000 2D447BD0 2D447BD0 YES
[03:39:58.090] FB03 00004000 AC08E666 AC08E666 YES
[03:39:58.417] FB04 00004000 F1E88506 F1E88506 YES
[03:39:58.745] FB05 00004000 F827A198 F827A198 YES
[03:39:59.072] FB06 00004000 1D2DE901 1D2DE901 YES
[03:39:59.416] FB07 00004000 24B1156C 24B1156C YES
[03:39:59.743] FB08 00004000 7259CC9A 7259CC9A YES
[03:40:00.086] FB09 00004000 0E03A941 CF538AB9 NO
[03:40:00.414] FB10 00004000 142BDE67 142BDE67 YES
[03:40:00.726] reading ecu programming voltage
[03:40:00.757] programming voltage is 7.52 volts
[03:40:00.757] programming voltage is out of range!
Blindstuff
Postby sub7 » Mon May 21, 2007 7:01 pm
Could it be an indicator of weak car battery? It happen to me onced when I try to read the ECU, car battery shown green (maintenance free type). While reading the ECU half way, it just stop and return with CRC error, 2nd attempt seem to work.
After changing the car battery, it always work.
sub7
Postby Blindstuff » Mon May 21, 2007 7:06 pm
Can i turn the ignition off to try and reflash again?
ECUFlash said NOT to
Blindstuff
Postby Blindstuff » Mon May 21, 2007 7:24 pm
I turned the ignition back, unpluged and the car started no problem, also read my ecu again. Everything is fine, but I dont dare try to flash again until colby takes a look at the log to see what happened. Got scared shittless
Blindstuff
Postby sub7 » Mon May 21, 2007 8:04 pm
Embarrassly speaking, I still had not flash my ECU. I did test write to ECU and it seem to be working.
[00:27:32.328] sending init sequence 1 (0001)
[00:27:33.375] got 0x05 response
[00:27:33.375] sending init sequence 2
[00:27:33.390] got 0x1B response
[00:27:33.390] sending init sequence 3
[00:27:33.796] entering bootloader
[00:27:33.828] sending kernel size (3500)
[00:27:33.859] sending kernel load address (0xFFFF8800)
[00:27:33.890] uploading kernel
[00:27:34.468] verifying kernel checksum response
[00:27:34.468] kernel valid
[00:27:34.687] kernel get version
[00:27:34.703] kernel version is : OpenECU Mitsubishi SH7052 Kernel V1.02
[00:27:34.703] reading kernel comm buffer size
[00:27:34.718] comm buffer size set to 512
[00:27:34.718] reading kernel flash buffer size
[00:27:34.750] flash buffer size set to 4096
[00:27:34.750] Test flashing image to ECU memory...
[00:27:35.140] comparing ECU flash memory pages to image file
[00:27:35.140] segment len ecu CRC32 img CRC32 same?
[00:27:35.171] FB01 00001000 15C254E4 15C254E4 YES
[00:27:35.203] FB02 00001000 110B52FB 110B52FB YES
[00:27:35.234] FB03 00001000 07625918 07625918 YES
[00:27:35.265] FB04 00001000 574E02F4 574E02F4 YES
[00:27:35.296] FB05 00001000 EC53A673 EC53A673 YES
[00:27:35.328] FB06 00001000 363D6B99 363D6B99 YES
[00:27:35.359] FB07 00001000 F154670A F154670A YES
[00:27:35.390] FB08 00001000 F154670A F154670A YES
[00:27:35.531] FB09 00008000 74290A5D 74290A5D YES
[00:27:35.812] FB10 00010000 CA9523A1 CA9523A1 YES
[00:27:36.062] FB11 00010000 CFFE6908 CFFE6908 YES
[00:27:36.328] FB12 00010000 92BA4138 92BA4138 YES
[00:27:36.328] flash image is identical! exiting.
sub7
