please help :-)
please help :-)
Postby jak » Fri May 11, 2007 7:57 am
hi there guys Ive had several versions of the reflashing SW & the USB cable for some time & have never been able to get it to work......
with the most recent attempt this is what I get from the log
[22:15:29.379] Version 1.30.1095
[22:15:29.389] 8 memory models read.
[22:15:35.939] 145 ROM metadata models read.
[22:15:35.939] checksum module "subarudbw" loaded.
[22:15:35.939] flashing tool "wrx02" loaded.
[22:15:35.939] flashing tool "wrx04" loaded.
[22:15:35.939] flashing tool "sti04" loaded.
[22:15:35.939] flashing tool "sti05" loaded.
[22:15:35.939] flashing tool "mitsukernel" loaded.
[22:15:35.939] flashing tool "mitsukernelocp" loaded.
[22:15:35.939] flashing tool "mitsubootloader" loaded.
[22:15:40.585] error loading FTChipID.DLL
I only have this car here for a few more days & any help anyone would be willing to give would be greatly apriciated
& if you guys can get me thru this definatly worth a $100 donation to the site although its not much its what I can afford
thanks JAK
jak
Postby sub7 » Fri May 11, 2007 8:07 am
Locate FTChipID.DLL in your ECUFlash directory, then copy that into your c:\windows\system32
sub7
Postby jak » Fri May 11, 2007 8:15 am
I wanted to say as well that the fans are cycling & both conectors are conected
it does the same thing weather the cable is pluged into the car or not, the computer or not.....
thanks
JAK
jak
Postby jak » Fri May 11, 2007 9:40 am
[00:25:21.968] Version 1.30.1095
[00:25:21.978] 8 memory models read.
[00:25:25.854] 145 ROM metadata models read.
[00:25:25.854] checksum module "subarudbw" loaded.
[00:25:25.854] flashing tool "wrx02" loaded.
[00:25:25.854] flashing tool "wrx04" loaded.
[00:25:25.854] flashing tool "sti04" loaded.
[00:25:25.854] flashing tool "sti05" loaded.
[00:25:25.854] flashing tool "mitsukernel" loaded.
[00:25:25.854] flashing tool "mitsukernelocp" loaded.
[00:25:25.864] flashing tool "mitsubootloader" loaded.
Ok thanks on that one but Istill cant seemto get past this
there are no prompts or anything
my computer sees the cable & port could it be a configuration problem?
thanks again for your time
take care
JAK
jak
Postby sub7 » Fri May 11, 2007 7:13 pm
Which ROM you trying to read? With my e7 in 1.29, I can't read the stock ROM so I got to search for my e7 definition file (in xml) and put it under rommetadata.
sub7
Users browsing this forum: Google [Bot] and 38 guests
