Hi Merchgod and Fungoolie,
Just been reading your Q&A's on the topic of flashing an MY07 ADM STi, and being new to this I have a question you good gent's might be able to answer please?
I read from the ECU no problem with ECUFlash, the hex image is as standard (exact as Fungoolie's) and I can open and edit using ECUEdit and Enginuity.
I though of starting with the very basics to ensure the programs edit correctly and the hex image is kept correct (checksums etc) so I adjusted the idle values with Enginuity, saved and opened in ECUEdit and vice-versa and both displayed the correct information as changed.
Now, when I viewed the idle tables in ECUFlash (sanity check prior to flashing to the car ECU) the table is far from what Enginuity and ECUEdit show? So what is happening here? Have you experienced this? Also the Target Boost tables in ECUFlash do not show the correct number of columns or values as Enginuity and ECUEdit do?
Any help or advice would be much appreciated
Many thanks,
Scooby34v.
