when upgrading to newer ecuflash??
Postby kreionic » Fri Mar 23, 2007 2:11 pm
Qiuck question when upgrading from ecuflash 1.29 to 1.30. Do I unistall 1.29 first? Does it save all my maps and transfer them to the 1.30 or do I manually do move the maps to 1.30?
kreionic
Postby s2p2 » Fri Mar 23, 2007 10:00 pm
It is installed back to the directory c:\Program Files\openecu\ecuflash.
Suggest you
1) Take a back up of the directory
2) Uninstall 1.29
3) Uninstall all the tactrix drivers.
4) Delete the directory
5) Install 1.3
You may or may not need to delete the directory, but many of us have issue with the upgrade from 1.29 to 1.3 so i guess a clean start will be good. BTW, if you are on win2k.....no one has managed to get it to work on that OS
s2p2
Postby kreionic » Sat Mar 24, 2007 2:11 pm
No i am good I use xp. I am up in the air with upgrading at this point cause it seems like everyone is having issues with 1.30
kreionic
Postby s2p2 » Sun Mar 25, 2007 5:04 am
kreionic wrote:No i am good I use xp. I am up in the air with upgrading at this point cause it seems like everyone is having issues with 1.30
I am ok on xp, dead on w2k
s2p2
Postby Zamot » Mon Apr 02, 2007 5:55 am
How do I uninstall the tactrix drivers?
Zamot
Postby s2p2 » Mon Apr 02, 2007 6:27 am
go to control panel, choose add/remove software.....scroll to the end, there's 2 tactrix drivers there
s2p2
