Need definition file
Postby silens » Sun Jan 14, 2007 11:47 am
Ok, i got the cable and ecuflash, i can download from the ecu fine, but i get an error when i try to open any tables " the current map description is invalid ... "
Im working on an 04 Lancer OZ Manual, does anyone have the def files for it? i will attach my saved hex if that helps
thank you
lancer04stock.hex
(256 KiB) Downloaded 896 times
silens
Re: Need definition file
Postby yamomoto » Sun Jan 14, 2007 1:35 pm
It is MN132864 (JM92290014) , can look in I-net.
I use other ROM-Editor, you can not use my MAPs.
But in JM92290014 classical architecture, you can write .xml-file for 15 min.
yamomoto
Postby silens » Sun Jan 14, 2007 1:44 pm
no idea what your talking about, i searched google for MN132864 all that comes up are places to buy the stock ecu :?
silens
Postby yamomoto » Sun Jan 14, 2007 2:04 pm
It is necessary to wait, can be at somebody is jm92290014.xml
If there is no - I shall help.
yamomoto
Postby Andreo » Tue Dec 04, 2007 1:12 am
Hello !!!
Help me please with definition file for software downloaded from my 2004 Lancer, 4G18, manual. Definition 92290014 and other for my software 2004 Lancer not worked. So I needed a new definition file.
Thank you !!!
This is my software:
My Lancer 2004.hex
Stock ROM 2004 lancer 4g18 manual
(256 KiB) Downloaded 884 times
Andreo
