Flash block connector using ECUFlash 1.00.63
Postby crispyduck » Sun Nov 20, 2005 11:51 am
qoncept wrote:Steve, let me know. If your ecu version isn't supported I'll get it in there.
Thanks for that. Looks like my ECU is not supported yet. I've posted to your Enginuity thread with details and a link to my ROM image I've uploaded.
Thanks,
Postby peewee » Mon Nov 21, 2005 1:59 am
Hi
Mine is working also fine on the bench now.
I will post the connections in my other thread.
Thanks All!
I will upload the image it seems already be a tuned file.
peewee
Jumpering pins?
Postby New2Scoobs » Mon Nov 21, 2005 6:20 am
Steve, what did you use to jumper the pins?
Re: Jumpering pins?
Postby crispyduck » Mon Nov 21, 2005 8:05 am
New2Scoobs wrote:Steve, what did you use to jumper the pins?
Simply two bits of wire, stripped and 'tinned' with a soldering iron. They pushed in to the end of the connector quite securey.
Help - My "flash connector" is different!
Postby New2Scoobs » Fri Nov 25, 2005 12:38 pm
Just went to backup my ECU ROM, about to jumper the pins as described at the beginning of this thread but I don't have the same connector.
My car is a 2001 Impreza WRX Euro (uk). My white connector has like 3 female ports, 2 are wired and one is empty. It's not a square block connector like the one in the picture it's more of a triangular shape.
Anyone else have the same?
I tried with just the green connectors connected but that didn't work.
Re: Help - My "flash connector" is different!
Postby crispyduck » Fri Nov 25, 2005 2:03 pm
New2Scoobs wrote:Just went to backup my ECU ROM, about to jumper the pins as described at the beginning of this thread but I don't have the same connector.
New2Scoobs, I've now found out from this forum that all Imprezas need to 'connect' the flash block even to read the ECU ROM.
Please see below an illustration of two connectors the professionals use to jumper the flash block connector. Note that these connectors fit on to ones under the dash so they are the male side of the connector - you'll see the female side under your dash.
Image Image
I assume you have the 2002 connector as above? If so you just need connect those pins together with a wire.
Hope this helps.You should now be able to read your ECU image. I'll update my instructions soon for Reading and Reflashing ECUs Using ECUFlash to cater for these different connectors.
Let us know how you get on,
Editted to say that I have created a page to document connecting to your ECU. If you find any errors please edit (adding an author name/nickname).
Postby New2Scoobs » Sat Nov 26, 2005 6:50 am
Thanks Steve, that worked.
Cheers
Mark.
Postby Spiider » Sun Nov 27, 2005 11:45 am
BTW, you can leave the "flash block" connected permanently.
Mine is always jumpered.
Obviously the green diag have to be connected and disconnected for flashing, you can put a switch in there to make it more easy than crawling under the dash everytime you want to do something.
Postby intrawrx » Wed Nov 30, 2005 7:00 pm
Hi Guys,
I've tried to communicate with an AU WRX (MY05) ECU, [AJ850-8930].
I have jumpered the flash block connector and it has not successfully downloaded a ROM yet. I am able to get ECUEXPLORER working for logging and resetting the ECU, would anyone have tips for this ecu?
I will download PORT MON to capture some data on whats happening on connect...
intrawrx
Postby calvinc » Wed Nov 30, 2005 10:59 pm
did you have both the green connector and flash block jumpered? i have done numerous SA vehicles which share the same spec as AUS. i havent tried with the newer graphical version yet though. the console app worked 100%.
Postby intrawrx » Wed Nov 30, 2005 11:08 pm
Calvin,
Yep, had the green connector (diag connector) connected and the flash block.
intrawrx
Postby New2Scoobs » Thu Dec 01, 2005 2:38 am
I found that timing was everything when it came to downloading my ROM. I had to be VERY quick clicking the "OK" button after turning the ignition to ON in order to get it to read.
Mark.
help
Postby dust12 » Mon Dec 05, 2005 8:00 pm
I am having problems downloading my ecu using ecuflash. Maybe someone out there can help figure out what my problem is.
Ecuexplorer works and the ecu type is 02 WRX (US) [AF423].
I have connected the green diagnostics cable together and have tried this with and without the flash block jumpered. I tried both the 02wrx and 04 wrx options.
The only thing I can think of is I have an **Utek license installed, do you think this would prevent this from working? Do you have any suggestions for me to try?
Below are the logs from ecuflash and portmon
Log from ecuflash
    [0.000] kernel flash disable
    [3.034] denso02_bootloader_cmd_start
    [0.030] 1452 byte kernel read.
    [0.000] kernel checksum is valid (n = 2).
    [0.200] writing denso kernel area addr: 020000 len: 05AC
    [2.855] kernel get version
    [2.022] unable to load kernel
portmon log
    0 6:16:50 PM ecuflash.exe IRP_MJ_CREATE VCP0 SUCCESS Options: Open
    1 6:16:50 PM ecuflash.exe IOCTL_SERIAL_SET_QUEUE_SIZE VCP0 SUCCESS InSize: 16384 OutSize: 16384
    2 6:16:50 PM ecuflash.exe IOCTL_SERIAL_GET_BAUD_RATE VCP0 SUCCESS
    3 6:16:50 PM ecuflash.exe IOCTL_SERIAL_GET_LINE_CONTROL VCP0 SUCCESS
    4 6:16:50 PM ecuflash.exe IOCTL_SERIAL_GET_CHARS VCP0 SUCCESS
    5 6:16:50 PM ecuflash.exe IOCTL_SERIAL_GET_HANDFLOW VCP0 SUCCESS
    6 6:16:50 PM ecuflash.exe IOCTL_SERIAL_GET_BAUD_RATE VCP0 SUCCESS
    7 6:16:50 PM ecuflash.exe IOCTL_SERIAL_GET_LINE_CONTROL VCP0 SUCCESS
    8 6:16:50 PM ecuflash.exe IOCTL_SERIAL_GET_CHARS VCP0 SUCCESS
    9 6:16:50 PM ecuflash.exe IOCTL_SERIAL_GET_HANDFLOW VCP0 SUCCESS
    10 6:16:50 PM ecuflash.exe IOCTL_SERIAL_SET_BAUD_RATE VCP0 SUCCESS Rate: 4800
    11 6:16:50 PM ecuflash.exe IOCTL_SERIAL_CLR_RTS VCP0 SUCCESS
    12 6:16:50 PM ecuflash.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
    13 6:16:50 PM ecuflash.exe IOCTL_SERIAL_SET_LINE_CONTROL VCP0 SUCCESS StopBits: 1 Parity: NONE WordLength: 8
    14 6:16:50 PM ecuflash.exe IOCTL_SERIAL_SET_CHAR VCP0 SUCCESS EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
    15 6:16:50 PM ecuflash.exe IOCTL_SERIAL_SET_HANDFLOW VCP0 SUCCESS Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
    16 6:16:50 PM ecuflash.exe IOCTL_SERIAL_SET_TIMEOUTS VCP0 SUCCESS RI:-1 RM:0 RC:0 WM:50 WC:0
    17 6:16:50 PM ecuflash.exe IOCTL_SERIAL_SET_WAIT_MASK VCP0 SUCCESS Mask: CTS DSR
    18 6:16:50 PM ecuflash.exe IRP_MJ_FLUSH_BUFFERS VCP0 SUCCESS
    19 6:16:50 PM ecuflash.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
    20 6:16:50 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    21 6:16:50 PM ecuflash.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
    22 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    23 6:17:02 PM ecuflash.exe IOCTL_SERIAL_SET_QUEUE_SIZE VCP0 SUCCESS InSize: 16384 OutSize: 16384
    24 6:17:02 PM ecuflash.exe IOCTL_SERIAL_GET_BAUD_RATE VCP0 SUCCESS
    25 6:17:02 PM ecuflash.exe IOCTL_SERIAL_GET_LINE_CONTROL VCP0 SUCCESS
    26 6:17:02 PM ecuflash.exe IOCTL_SERIAL_GET_CHARS VCP0 SUCCESS
    27 6:17:02 PM ecuflash.exe IOCTL_SERIAL_GET_HANDFLOW VCP0 SUCCESS
    28 6:17:02 PM ecuflash.exe IOCTL_SERIAL_GET_BAUD_RATE VCP0 SUCCESS
    29 6:17:02 PM ecuflash.exe IOCTL_SERIAL_GET_LINE_CONTROL VCP0 SUCCESS
    30 6:17:02 PM ecuflash.exe IOCTL_SERIAL_GET_CHARS VCP0 SUCCESS
    31 6:17:02 PM ecuflash.exe IOCTL_SERIAL_GET_HANDFLOW VCP0 SUCCESS
    32 6:17:02 PM ecuflash.exe IOCTL_SERIAL_SET_BAUD_RATE VCP0 SUCCESS Rate: 39473
    33 6:17:02 PM ecuflash.exe IOCTL_SERIAL_CLR_RTS VCP0 SUCCESS
    34 6:17:02 PM ecuflash.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
    35 6:17:02 PM ecuflash.exe IOCTL_SERIAL_SET_LINE_CONTROL VCP0 SUCCESS StopBits: 1 Parity: NONE WordLength: 8
    36 6:17:02 PM ecuflash.exe IOCTL_SERIAL_SET_CHAR VCP0 SUCCESS EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
    37 6:17:02 PM ecuflash.exe IOCTL_SERIAL_SET_HANDFLOW VCP0 SUCCESS Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
    38 6:17:02 PM ecuflash.exe IOCTL_SERIAL_SET_TIMEOUTS VCP0 SUCCESS RI:-1 RM:0 RC:0 WM:50 WC:0
    39 6:17:02 PM ecuflash.exe IOCTL_SERIAL_SET_WAIT_MASK VCP0 SUCCESS Mask: CTS DSR
    40 6:17:02 PM ecuflash.exe IRP_MJ_FLUSH_BUFFERS VCP0 SUCCESS
    41 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    42 6:17:02 PM ecuflash.exe IRP_MJ_WRITE VCP0 SUCCESS Length 6: BE EF 00 01 21 CF
    43 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    44 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    45 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: BE
    46 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: EF
    47 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: 00
    48 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: 01
    49 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: 21
    50 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: CF
    51 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    52 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    53 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    54 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    55 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    56 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    57 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    58 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    59 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    60 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    61 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    62 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    63 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    64 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    65 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    66 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    67 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    68 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    69 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    70 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    71 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    72 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    73 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    74 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    75 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    76 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    77 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    78 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    79 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    80 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    81 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    82 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    83 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    84 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    85 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    86 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    87 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    88 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    89 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    90 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    91 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    92 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    93 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    94 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    95 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    96 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    97 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    98 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    99 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    100 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    101 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    102 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    103 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    104 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    105 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    106 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    107 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    108 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    109 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    110 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    111 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    112 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    113 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    114 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    115 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    116 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    117 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    118 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    119 6:17:02 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    120 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    121 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    122 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    123 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    124 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    125 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    126 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    127 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    128 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    129 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    130 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    131 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    132 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    133 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    134 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    135 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    136 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    137 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    138 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    139 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    140 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    141 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    142 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    143 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    144 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    145 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    146 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    147 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    148 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    149 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    150 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    151 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    152 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    153 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    154 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    155 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    156 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    157 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    158 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    159 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    160 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    161 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    162 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    163 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    164 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    165 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    166 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    167 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    168 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    169 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    170 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    171 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    172 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    173 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    174 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    175 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    176 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    177 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    178 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    179 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    180 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    181 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    182 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    183 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    184 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    185 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    186 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    187 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    188 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    189 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    190 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    191 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    192 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    193 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    194 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    195 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    196 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    197 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    198 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    199 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    200 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    201 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    202 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    203 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    204 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    205 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    206 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    207 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    208 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    209 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    210 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    211 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    212 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    213 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    214 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    215 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    216 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    217 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    218 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    219 6:17:03 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    220 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    221 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    222 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    223 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    224 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    225 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    226 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    227 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    228 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    229 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    230 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    231 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    232 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    233 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    234 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    235 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    236 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    237 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    238 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    239 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    240 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    241 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    242 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    243 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    244 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    245 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    246 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    247 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    248 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    249 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    250 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    251 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    252 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    253 6:17:04 PM ecuflash.exe IOCTL_SERIAL_SET_QUEUE_SIZE VCP0 SUCCESS InSize: 16384 OutSize: 16384
    254 6:17:04 PM ecuflash.exe IOCTL_SERIAL_GET_BAUD_RATE VCP0 SUCCESS
    255 6:17:04 PM ecuflash.exe IOCTL_SERIAL_GET_LINE_CONTROL VCP0 SUCCESS
    256 6:17:04 PM ecuflash.exe IOCTL_SERIAL_GET_CHARS VCP0 SUCCESS
    257 6:17:04 PM ecuflash.exe IOCTL_SERIAL_GET_HANDFLOW VCP0 SUCCESS
    258 6:17:04 PM ecuflash.exe IOCTL_SERIAL_GET_BAUD_RATE VCP0 SUCCESS
    259 6:17:04 PM ecuflash.exe IOCTL_SERIAL_GET_LINE_CONTROL VCP0 SUCCESS
    260 6:17:04 PM ecuflash.exe IOCTL_SERIAL_GET_CHARS VCP0 SUCCESS
    261 6:17:04 PM ecuflash.exe IOCTL_SERIAL_GET_HANDFLOW VCP0 SUCCESS
    262 6:17:04 PM ecuflash.exe IOCTL_SERIAL_SET_BAUD_RATE VCP0 SUCCESS Rate: 9600
    263 6:17:04 PM ecuflash.exe IOCTL_SERIAL_CLR_RTS VCP0 SUCCESS
    264 6:17:04 PM ecuflash.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
    265 6:17:04 PM ecuflash.exe IOCTL_SERIAL_SET_LINE_CONTROL VCP0 SUCCESS StopBits: 1 Parity: NONE WordLength: 8
    266 6:17:04 PM ecuflash.exe IOCTL_SERIAL_SET_CHAR VCP0 SUCCESS EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
    267 6:17:04 PM ecuflash.exe IOCTL_SERIAL_SET_HANDFLOW VCP0 SUCCESS Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
    268 6:17:04 PM ecuflash.exe IOCTL_SERIAL_SET_TIMEOUTS VCP0 SUCCESS RI:-1 RM:0 RC:0 WM:50 WC:0
    269 6:17:04 PM ecuflash.exe IOCTL_SERIAL_SET_WAIT_MASK VCP0 SUCCESS Mask: CTS DSR
    270 6:17:04 PM ecuflash.exe IRP_MJ_FLUSH_BUFFERS VCP0 SUCCESS
    271 6:17:04 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    272 6:17:04 PM ecuflash.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
    273 6:17:04 PM ecuflash.exe IOCTL_SERIAL_CLR_DTR VCP0 SUCCESS
    274 6:17:05 PM ecuflash.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
    275 6:17:05 PM ecuflash.exe IRP_MJ_WRITE VCP0 SUCCESS Length 3: 4D FF B4
    276 6:17:05 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    277 6:17:05 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 3: 4D FF B4
    278 6:17:05 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    279 6:17:05 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    280 6:17:05 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 3: 4D 00 B3
    281 6:17:05 PM ecuflash.exe IRP_MJ_WRITE VCP0 SUCCESS Length 1459: 53 02 00 00 05 AC F5 5D 39 41 65 65 84 41 2A 35 40 4B 20 26 10
    282 6:17:06 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1330: 53 02 00 00 05 AC F5 5D 39 41 65 65 84 41 2A 35 40 4B 20 26 10
    283 6:17:06 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 15: 52 5D 64 6C 72 F0 64 D5 BF 67 67 A9 82 B2 71
    284 6:17:06 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    285 6:17:06 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 15: 64 B0 6A 72 D8 72 F8 B2 E5 72 09 30 25 72 81
    286 6:17:06 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 16: 72 98 70 25 82 B2 82 8C 62 FB BA BA 82 8C 62 A5
    287 6:17:07 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    288 6:17:07 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 15: BA BA 82 B2 71 66 52 41 62 A4 52 4F 62 A4 72
    289 6:17:07 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    290 6:17:07 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 15: 70 65 6D 82 8A 62 FB 82 8B 62 A5 F1 51 72 F0
    291 6:17:07 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 16: E6 85 72 C1 62 A5 72 CF 62 A5 72 F0 C8 FD 72 C1
    292 6:17:07 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    293 6:17:07 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 15: 62 FB 72 CF 62 FB 72 75 65 64 F3 91 70 45 82
    294 6:17:07 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 16: B2 71 64 82 85 62 FB 82 85 62 A5 82 2B 72 F9 62
    295 6:17:07 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    296 6:17:07 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 6: FB 70 25 82 B2 05
    297 6:17:07 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    298 6:17:07 PM ecuflash.exe IOCTL_SERIAL_SET_QUEUE_SIZE VCP0 SUCCESS InSize: 16384 OutSize: 16384
    299 6:17:07 PM ecuflash.exe IOCTL_SERIAL_GET_BAUD_RATE VCP0 SUCCESS
    300 6:17:07 PM ecuflash.exe IOCTL_SERIAL_GET_LINE_CONTROL VCP0 SUCCESS
    301 6:17:07 PM ecuflash.exe IOCTL_SERIAL_GET_CHARS VCP0 SUCCESS
    302 6:17:07 PM ecuflash.exe IOCTL_SERIAL_GET_HANDFLOW VCP0 SUCCESS
    303 6:17:07 PM ecuflash.exe IOCTL_SERIAL_GET_BAUD_RATE VCP0 SUCCESS
    304 6:17:07 PM ecuflash.exe IOCTL_SERIAL_GET_LINE_CONTROL VCP0 SUCCESS
    305 6:17:07 PM ecuflash.exe IOCTL_SERIAL_GET_CHARS VCP0 SUCCESS
    306 6:17:07 PM ecuflash.exe IOCTL_SERIAL_GET_HANDFLOW VCP0 SUCCESS
    307 6:17:07 PM ecuflash.exe IOCTL_SERIAL_SET_BAUD_RATE VCP0 SUCCESS Rate: 39473
    308 6:17:07 PM ecuflash.exe IOCTL_SERIAL_CLR_RTS VCP0 SUCCESS
    309 6:17:07 PM ecuflash.exe IOCTL_SERIAL_SET_DTR VCP0 SUCCESS
    310 6:17:07 PM ecuflash.exe IOCTL_SERIAL_SET_LINE_CONTROL VCP0 SUCCESS StopBits: 1 Parity: NONE WordLength: 8
    311 6:17:07 PM ecuflash.exe IOCTL_SERIAL_SET_CHAR VCP0 SUCCESS EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
    312 6:17:07 PM ecuflash.exe IOCTL_SERIAL_SET_HANDFLOW VCP0 SUCCESS Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
    313 6:17:07 PM ecuflash.exe IOCTL_SERIAL_SET_TIMEOUTS VCP0 SUCCESS RI:-1 RM:0 RC:0 WM:50 WC:0
    314 6:17:07 PM ecuflash.exe IOCTL_SERIAL_SET_WAIT_MASK VCP0 SUCCESS Mask: CTS DSR
    315 6:17:07 PM ecuflash.exe IRP_MJ_FLUSH_BUFFERS VCP0 SUCCESS
    316 6:17:07 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    317 6:17:08 PM ecuflash.exe IRP_MJ_WRITE VCP0 SUCCESS Length 6: BE EF 00 01 01 AF
    318 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    319 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    320 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: BE
    321 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: EF
    322 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: 00
    323 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: 01
    324 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: 01
    325 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 1: AF
    326 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    327 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    328 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    329 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    330 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    331 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    332 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    333 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    334 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    335 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    336 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    337 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    338 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    339 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    340 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    341 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    342 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    343 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    344 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    345 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    346 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    347 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    348 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    349 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    350 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    351 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    352 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    353 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    354 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    355 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    356 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    357 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    358 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    359 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    360 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    361 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    362 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    363 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    364 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    365 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    366 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    367 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    368 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    369 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    370 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    371 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    372 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    373 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    374 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    375 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    376 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    377 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    378 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    379 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    380 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    381 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    382 6:17:08 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    383 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    384 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    385 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    386 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    387 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    388 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    389 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    390 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    391 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    392 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    393 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    394 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    395 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    396 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    397 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    398 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    399 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    400 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    401 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    402 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    403 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    404 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    405 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    406 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    407 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    408 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    409 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    410 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    411 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    412 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    413 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    414 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    415 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    416 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    417 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    418 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    419 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    420 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    421 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    422 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    423 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    424 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    425 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    426 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    427 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    428 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    429 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    430 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    431 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    432 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    433 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    434 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    435 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    436 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    437 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    438 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    439 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    440 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    441 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    442 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    443 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    444 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    445 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    446 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    447 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    448 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    449 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    450 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    451 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    452 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    453 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    454 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    455 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    456 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    457 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    458 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    459 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    460 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    461 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    462 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    463 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    464 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    465 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    466 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    467 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    468 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    469 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    470 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    471 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    472 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    473 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    474 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    475 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    476 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    477 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    478 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    479 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    480 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    481 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    482 6:17:09 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    483 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    484 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    485 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    486 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    487 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    488 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    489 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    490 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    491 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    492 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    493 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    494 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    495 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    496 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    497 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    498 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    499 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    500 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    501 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    502 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    503 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    504 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    505 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    506 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    507 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    508 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    509 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    510 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    511 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    512 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    513 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    514 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    515 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    516 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    517 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    518 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    519 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    520 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    521 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    522 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    523 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    524 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    525 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    526 6:17:10 PM ecuflash.exe IRP_MJ_READ VCP0 SUCCESS Length 0:
    527 6:17:10 PM ecuflash.exe IRP_MJ_CLEANUP VCP0 SUCCESS
    528 6:17:10 PM ecuflash.exe IRP_MJ_CLOSE VCP0 SUCCESS
dust12
Postby cboles » Tue Dec 06, 2005 9:05 am
I looked at your portmon log. Using to 2002 wrx option, EcuFlash is able to communicate with your ECU and upload the kernel code. For some reason, after the kernel code is uploaded, it cannot get a response from the kernel. I'm not sure why. A couple of possibilities I can think of are:
* Your ECU, wiring harness, or something additional you have attached to the OBD lines is preventing the ECU from communicating at the higher ~39k baud rate of the kernel. I can see that the OpenPort is working OK at these rates though.
* The TPU area code in your ECU which is responsible for bootloading the kernel is different from what I have seen and expects a different kernel checksum, or checksums by a different method. ***tek could modify the TPU area like this, but then a Subaru dealer would not be able to load their kernel either.
I'll think about it a bit more, but neither of these scenarios seem very likely to me...
Re: Jumpering pins?
Postby BLUES » Sun Jan 08, 2006 6:20 am
will any wire do?
BLUES
