by Twinturbo » Thu Dec 14, 2006 10:57 pm
No, the car is not in closed loop at full throttle. The AFR values are calculations that the ECU targets, but they are a bit off from the real, measured value. On my car I have to set the values 0.3-0.4 higher than what i get with my WBO. 11.9 in the table on full throttle and high boost correspond to 11.5 measured value, but it is different depending on your map. Se it as an estimated value.
Twinturbo on Sun Dec 17, 2006 10:44 pm, edited 1 time in total.
