programming voltage is 4.2 volts programming voltage is too
Postby peewee » Thu Feb 22, 2007 5:21 am
I had a near the same problem today with a 2002 WRX.
Reading programming voltage was 13v (with charger connected)
But stil the fault incorrect programming voltage.
Just disconnect the battery to reset the ecu and then flashing was ok.
@Killa996 did you connect the 3pole white flash connector?
Paul.
peewee
Postby Element Tuning » Thu Feb 22, 2007 10:42 am
Paul,
Thanks for the advice. I spoke with some of my contacts and apparently this is a problem with some of the early 02 WRX models which would only get around 4 volts therefore requiring +12v to be jumped to the flash block.
I haven't had time to test this as I've been traveling for tuning but I'll try this when I return.
Thanks,
Phil
www.elementtuning.com
Element Tuning
Postby Phatlines » Thu Mar 08, 2007 1:38 pm
I'm having the same issue, gonna try resetting my ECU and see what happens. The thing is, I've flashed my ecu a few times, then this all of a sudden started happening.
I did notice the file size is 16x,xxx instead of 192xxx is there a way to convert the file size or type the correct size/ type?
Phatlines
Postby Phatlines » Fri Mar 09, 2007 11:35 am
Well I got a wiring diagram and found the connector, it doesn't connect to anything else, its getting its 12v+ supply from who knows where. I am going to try and trace the wire as far as I can. I guess running 12v to the correct side of the block would work just fine.
Phatlines
Postby Element Tuning » Fri Mar 09, 2007 6:02 pm
I had a narrow window of time which I missed to test all of this but yes just make sure you jump +12v to the correct side. I have not confirmed this actually works.
Good luck.
Phil
Element Tuning
Postby Phatlines » Sun Mar 11, 2007 9:26 am
Try this, you should have 12v coming through on your OBDII port. Check pins 12(+) and 4(-) while your key is in the on position. I believe there should be 12v there. I am at 4.1v there as well.
Phatlines
Postby Phatlines » Mon Mar 12, 2007 7:31 am
Ok, I ran a 12v line to the blue wire (6th pin on the OBDII port). This 12v is only supplying the voltage when the ignition is on.
I can now flash back to the ecu with no issues.
Phatlines
Postby ride5000 » Sun Apr 22, 2007 9:57 am
after a lot of verifying with a DMM, i strapped a 12v supply, energized with the ignition, right to the flash block.
i used solid core 18awg and pushed it right into the flash block. it needs to connect to the red/yellow stripe conductor (4 pin my03 style flashblock).
programming voltage is now battery voltage and two test flashes went perfectly fine.
i still don't know why it worked at some point, then stopped working. i'll probably never know, but i'm glad to be flashing again! :)
hth
ken
ride5000
Postby Element Tuning » Mon Apr 23, 2007 7:22 am
I have jumped +12v to the power wire and I can sucessfully flash now but I actually get voltage that is too high now. I usually have to turn my headlights on to get voltage to drop below 12.3 volts to flash.
Thanks,
Phil
Element Tuning
Postby mxturboracer86 » Thu Apr 26, 2007 3:24 am
yep i got my friends 02 to work... i just ran a wire straight from the block to the battery (actually going to make a wire just for this when i get a chang) and turned the A/C and headlights on to get the voltage down to low enough
mxturboracer86
Postby Hyper » Thu Apr 26, 2007 7:30 am
so what happens if the voltage is higher then 12v, you can burn something?
Hyper
Postby Element Tuning » Thu Apr 26, 2007 8:14 am
Hyper wrote:so what happens if the voltage is higher then 12v, you can burn something?
It just won't allow the ecu to be flashed. It will give a "voltage too high" error message. All you need to do is turn the head lights on and the voltage will drop within the parameters of flashing.
Thanks,
Phil
Element Tuning
Postby Hyper » Tue May 01, 2007 6:58 pm
ok, my turn to call for help :)
I've been getting same error, low voltage 4.2V (or 4.4, forgot)
however I have no problems reading the ROM/logging the car with deltadash/my old ECU was reflashed with ECUTEK many times - no problems at all
so it means that I have all wires in place (I have a swapped car, so wiring can be a real PITA)
I went in there today to check voltage and the only variation I saw was pin 9
this is what I observed:
test connectors disconnected/connected - 5V
test connectors disconnected/connected WITH openport cable connected to laptop - 9V (9.1~9.3V was jumping when I switched lights/AC)
does this mean this pin 9 is the one that I have to jump with 12V? I am unsure because I expected to see same reading on voltmeter as the flashecu shows me 4.4V
Hyper
Postby Hyper » Sun May 06, 2007 8:52 pm
if I understand correctly, this mystery wire has to go to one of the pins of ECU providing it with 12V of voltage for flashing, it that right?
Hyper
Postby Freon » Sun May 06, 2007 8:55 pm
Correct.
