I'm trying to reflash a 05 US STI... I can read the map from the ecu fine, but the problem I'm running into is when I go to write a new image, it fails with the following:
[07:37:38.856] ssm2_init
[07:37:39.087] ssm2_init
[07:37:39.307] ssm2_init
[07:37:39.527] ssm2_init
[07:37:39.758] ssm2_init
[07:37:39.978] ssm2_init
[07:37:40.198] ssm2_init
[07:37:40.429] ssm2_init
[07:37:40.649] ssm2_init
[07:37:40.869] ssm2_init
[07:37:41.290] kernel get version
[07:37:41.841] validating denso kernel ram area addr: 020000 len: 0008
Then it says error check the logs. Attached is the image I downloaded from the car. It's ID is A2ZJB11J. Am I recieving this error because I am trying to flash a rom with the ID of A4TF800F and the ID doesnt match?
TIA
