ECUFlash - Support for USDM 07 WRX?
Postby Jeramie » Sun Oct 29, 2006 6:14 pm
Just wondering if the USDM 07 WRX should be supported by ECUFlash. I tried to dump the image tonight and obviously it didn't work.
If it's not supported do you have a time frame of when it will be? Thnx
Jeramie
Postby merchgod » Sun Oct 29, 2006 8:18 pm
Someone dumped an 07 sti rom with Ecuflash.
merchgod
Postby Jeramie » Mon Oct 30, 2006 5:25 am
I tried with my WRX and it woudln't even load the kernal?
Jeramie
Postby merchgod » Mon Oct 30, 2006 7:33 am
Do you get the radiator fans cycling?
merchgod
Postby Jeramie » Mon Oct 30, 2006 9:03 am
yeah, cel and fan cycling
Jeramie
Postby merchgod » Mon Oct 30, 2006 9:50 am
Do what Braden talked about in that other post. Remove tactrix driviers (should be 4 of them) from add/remove programs. Remove Ecuflash from add/remove programs. Restart. Download 1.29a Ecuflash and install. Even if you previously installed 1.29a, you still need to follow this uninstall process.
merchgod
Postby Jeramie » Mon Oct 30, 2006 11:54 am
Yeah I already did all that before bradens post. When first connecting 1.2 (I had 1.1 or 1.0 before) it wouldn't even find the cable. After reinstall (removed everything first of course) it will now find cable and Ecuexplorer works.
I have a log, of the flash process on my laptop. Will be posting it shortly.
Jeramie
Postby Jeramie » Tue Oct 31, 2006 12:20 pm
Heres the log.
error-log.txt
(885 Bytes) Downloaded 786 times
Jeramie
Postby merchgod » Tue Oct 31, 2006 12:25 pm
If you have recently installed 1.29a and haven't tried it on anything except this 07 wrx, I would try it on non-07 just to verify it isn't a driver issue.
There's also be mention of a white connector on the passenger's side is sometimes disconnected from the factory that will cause the dl to fail. Not sure where exactly it is, though. Somewhere above the footwell.
merchgod
Postby Jeramie » Tue Oct 31, 2006 12:35 pm
merchgod wrote:If you have recently installed 1.29a and haven't tried it on anything except this 07 wrx, I would try it on non-07 just to verify it isn't a driver issue.
1.29a has worked in past with 04. ..
The white connector is looking like the culprit!(Now just to find it) Thanks for the help and suggestions Mechgod. I apreciate it!
Should also meantion ecuexplorer works just fine.
Jeramie
Postby merchgod » Tue Oct 31, 2006 1:08 pm
Ecuexplorer doesn't require diagnostics mode to operate, so it could very well be the elusive white connector issue.
merchgod
Postby Jeramie » Tue Oct 31, 2006 1:46 pm
Got ya. But if ecuexplorer works, I would assume the drivers are ok!. Would you?
Does anyone know where (Which forum) they saw the post with the 07 STI with the funny white connectors?
Jeramie
Postby zigzagzok » Wed Nov 01, 2006 2:11 am
Jeramie wrote:Heres the log.
i have the same error for my 06 Legacy GT 6MT too... :(
zigzagzok
Postby Jeramie » Wed Nov 01, 2006 4:31 am
Really?
Hummm. I found the thread from the 07 STI guy and PM'd him but no response yet :( Thanks for the info.
Jeramie
Postby zigzagzok » Wed Nov 01, 2006 11:44 pm
Jeramie wrote:Really?
http://forums.openecu.org/viewtopic.php?t=1115
this is my thread showing the problem...
zigzagzok
