tapki wrote:example.xml
<rom>
<romid>
<xmlid>000000E6</xmlid>
<internalidhex>000000E6</internalidhex>
<caseid>none</caseid>
<ecuid>none</ecuid>
<make>Mitsubishi</make>
<market>USDM</market>
<model>LancerRalliArt</model>
<submodel>N/A</submodel>
<transmission>Auto</transmission>
<year>2004</year>
<flashmethod>mitsubootloader</flashmethod>
<memmodel>M32176F6</memmodel> *It can't be flashed with M32176F4 correctly (default for RalliArt 512K)
<checksummodule>mitsucan</checksummodule> *Without CHKSUM I've got a CEL and misfires
</romid> for 1.42 I'm used a file from 1.43.170? beta, becouse of 1.43 crashed in Vista, but under XP everything was fine.
folder: "read templates"
file: read_mitsum32176f6boot.xml :
<rom>
<romid>
<xmlid>read_mitsum32176f6boot</xmlid>
<market>ALL</market>
<model>Colt</model>
<submodel>(768k)</submodel>
<year>2006+?</year>
</romid>
</rom>
I don't read with RA 2004-2006, it won't work for me
I'm used next string "Colt 762K" 2006+ for all 4G69
Hello,
We convert our original Outlander Turbo 512kb rom file to 768k and edit the memmodel to M32176F6 and the checksum in the xml to able to open it by Ecuflash as you posted. The crc checksum problem was gone when you open the converted file.
We coundn't write in the converted file with M32176F6 in the xml, here is the log :
[23:14:10.213] EcuFlash Version 1.43.3252
[23:14:10.213] OS Version Windows 7
[23:14:10.213] Qt Version 4.6.2
[23:14:10.227] 62 memory models read.
[23:14:10.228] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[23:14:10.467] 358 ROM metadata models scanned.
[23:14:10.467] checksum module "subarudbw" loaded.
[23:14:10.467] checksum module "mitsucan" loaded.
[23:14:10.467] checksum module "mitsuh8" loaded.
[23:14:10.467] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[23:14:10.468] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[23:14:10.468] flashing tool "wrx02" loaded.
[23:14:10.468] flashing tool "wrx04" loaded.
[23:14:10.468] flashing tool "sti04" loaded.
[23:14:10.469] flashing tool "sti05" loaded.
[23:14:10.469] flashing tool "mitsukernel" loaded.
[23:14:10.469] flashing tool "mitsukernelocp" loaded.
[23:14:10.469] flashing tool "mitsubootloader" loaded.
[23:14:10.469] flashing tool "shbootmode" loaded.
[23:14:10.470] flashing tool "shaudmode" loaded.
[23:14:10.471] flashing tool "subarucan" loaded.
[23:14:10.471] flashing tool "subarucand" loaded.
[23:14:10.471] flashing tool "mitsucan" loaded.
[23:14:16.603] C7280009 (56 tables) inheriting evo10base (101 tables)
[23:14:16.629] 786432 byte image read.
[23:14:28.776] J2534 API Version: 04.04
[23:14:28.776] J2534 DLL Version: 1.00.3210 Nov 22 2010 23:18:50
[23:14:28.776] Device Firmware Version: 1.11.3209
[23:14:28.776] Device Serial Number: TALz8Qnz
[23:14:43.356] sending init sequence 1 (0001)
[23:14:44.368] got 0x05 response
[23:14:44.368] sending init sequence 2
[23:14:44.374] got 0x1A response instead of 0x1B
[23:14:44.378] sending init sequence 3
[23:14:44.732] entering bootloader
[23:14:44.741] interface close
[23:15:57.861] 786432 byte image read.
[23:17:30.081] 786432 byte image written.
[23:19:26.986] 786432 byte image written.
[23:20:11.674] 786432 byte image written.
[23:20:16.773] J2534 API Version: 04.04
[23:20:16.773] J2534 DLL Version: 1.00.3210 Nov 22 2010 23:18:50
[23:20:16.773] Device Firmware Version: 1.11.3209
[23:20:16.773] Device Serial Number: TALz8Qnz
[23:20:30.065] sending init sequence 1 (0001)
[23:20:31.104] got 0x05 response
[23:20:31.104] sending init sequence 2
[23:20:31.118] got 0x1A response instead of 0x1B
[23:20:31.118] sending init sequence 3
[23:20:31.469] entering bootloader
[23:20:31.483] interface close
Also we can read out ever the Outlander turbo ecu with Colt 786k.
