ECUFlash - Support for USDM 07 WRX?
Postby Jeramie » Tue Nov 07, 2006 6:07 am
cboles wrote:I wish I could be more help. I haven't had a chance to get my hands on a 07 car yet. It looks like the car is not responding all to the ssm init command while in the test mode... It sounds like it does while not in the test mode, since logging works. Maybe I can try giving you a version that doesn't do the ssm init, and see if it the rest of the reflash sequence still works... It would be nice to get the log from the working 07 STi reflash to see what happens there.
Cool beans. That would be great! Just let me know.
Jeramie
Postby Jeramie » Fri Nov 10, 2006 7:27 pm
Bump, to keep it fresh.
Jeramie
Postby zigzagzok » Mon Nov 13, 2006 7:14 am
Jeramie wrote:Bump, to keep it fresh.
just tried to datalog using engunity 0.4.0 - it works
but no luck on the downloading still....
zigzagzok
Postby Jeramie » Mon Nov 13, 2006 9:07 am
Yeah, I think we need to wait on Colby to get this one fixed. :(
Jeramie
Postby Jon [in CT] » Mon Nov 13, 2006 9:52 am
cboles wrote:It looks like the car is not responding all to the ssm init command while in the test mode... It sounds like it does while not in the test mode, since logging works.
Sounds like it's worth a shot to try reading the ROM without putting the car in test mode.
Postby Jeramie » Mon Nov 13, 2006 9:55 am
heh! 1 step ahead of you. I've tried it. No luck :(
Thanks for the suggestion tho! At this poing I pretty much willing to try anything.
Jeramie
Postby zigzagzok » Wed Nov 15, 2006 1:39 am
Jeramie wrote:heh! 1 step ahead of you. I've tried it. No luck :(
same here have tried but no luck :(
zigzagzok
Postby Jon [in CT] » Wed Nov 15, 2006 4:13 pm
Somebody has successfully pulled the ROM from a US 2007 5MT WRX. So maybe there's a problem with your configuration or hardware.
http://forums.openecu.org/viewtopic.php?t=1324
Postby Jeramie » Wed Nov 15, 2006 6:51 pm
Thanks for the tip! I sure hope it's a problem with my hardware.
Jeramie
Postby shane86 » Wed Nov 15, 2006 8:28 pm
Well, i'm the one who managed to pull it successfully.
i outlined my process in the other thread, but i'll copy it here as well.
1. Connect OpenPort 1.2 to car
2. connect green test connectors
3. connect OpenPort 1.2 to laptop (already on)
4. turn car on
5. launch ECU Flash 1.28.716
6. initiate ROM download
7. select "2005-2006 Subaru DBW models" when prompted.
8. ECU download commenced.
9. when it asked for a profile, i selected to create a new profile based on the 06 WRX and saved the file.
that's it. it just worked. nothing out of the ordanary.
After reading over this thread and a few like it, I'm beginning to believe that 1.29a might be the problem. i'd also make sure that the FTDI or what ever it is drivers are installed properly.
Personally, i'd look for a copy of 1.28 if you can find it and try that.
if you don't have any luck, i can try and zip mine up and send it to you.
i just never plunged into the 1.29, as i had no reason. i never really work with mitsus. just my 04 wrx and a few friends cars.
shane86
Postby Jeramie » Thu Nov 16, 2006 5:47 am
OMG!
1.28 works np! I can't belive it! But I'm thrilled at the same time! Thanks
Jeramie
Postby shane86 » Thu Nov 16, 2006 6:01 am
Time to poke colby a bit... see what he "messed up" in 1.29a
lol.
I'm glad it worked for you.
shane86
Postby Jeramie » Thu Nov 16, 2006 6:14 am
all I have to say is Thank You Thank You Thank You Thank You Thank You Thank You Thank you .. . I think you get the idea :D
Jeramie
Postby zigzagzok » Thu Nov 16, 2006 11:42 pm
Jeramie wrote:all I have to say is Thank You Thank You Thank You Thank You Thank You Thank You Thank you .. . I think you get the idea :D
lucky you :shock:
i still cant get that darned thing to download
have uninstalled ECUFLASH 1.29, removed the 3 FTDI drivers
reinstalled the ecuflash 1.28, reinstalled the FTDI drivers;
get a new error msg :x
this was using com4 - where the openport 1.3 cable was assigned to
[00:14:32.274] Version 1.28.716
[00:14:32.274] 8 memory models read.
[00:14:32.474] 72 ROM metadata models read.
[00:14:32.474] checksum module "subarudbw" loaded.
[00:14:32.474] flashing tool "wrx02" loaded.
[00:14:32.474] flashing tool "wrx04" loaded.
[00:14:32.474] flashing tool "sti04" loaded.
[00:14:32.474] flashing tool "sti05" loaded.
[00:14:32.474] flashing tool "mitsukernel" loaded.
[00:14:32.474] flashing tool "mitsukernelocp" loaded.
[00:14:32.474] flashing tool "mitsubootloader" loaded.
[00:14:57.600] ssm2_init
[00:14:57.861] ssm2_cmd_0x81
[00:15:24.849] ssm2_init
[00:15:25.100] ssm2_cmd_0x81
[00:16:31.645] ssm2_init
[00:16:31.906] ssm2_cmd_0x81
[00:16:53.637] ssm2_init
[00:16:53.897] ssm2_cmd_0x81
[00:17:23.430] ssm2_init
[00:17:23.680] ssm2_cmd_0x81
[00:17:56.247] ssm2_init
[00:17:56.497] ssm2_cmd_0x81
[00:18:23.867] ssm2_init
[00:18:24.127] ssm2_cmd_0x81
[00:18:52.117] ssm2_init
[00:18:52.378] ssm2_cmd_0x81
then i removed the drivers again and this time installed all except the serial port driver i get this error instead
[00:25:01.228] Version 1.28.716
[00:25:01.228] 8 memory models read.
[00:25:01.438] 71 ROM metadata models read.
[00:25:01.438] checksum module "subarudbw" loaded.
[00:25:01.438] flashing tool "wrx02" loaded.
[00:25:01.438] flashing tool "wrx04" loaded.
[00:25:01.438] flashing tool "sti04" loaded.
[00:25:01.438] flashing tool "sti05" loaded.
[00:25:01.438] flashing tool "mitsukernel" loaded.
[00:25:01.438] flashing tool "mitsukernelocp" loaded.
[00:25:01.438] flashing tool "mitsubootloader" loaded.
[00:25:10.251] unable to connect to vehicle interface.
[00:25:29.799] ssm2_init
[00:25:30.050] ssm2_init
[00:25:30.070] ssm2_init
[00:25:30.080] ssm2_init
[00:25:30.100] ssm2_init
[00:25:30.120] ssm2_init
[00:25:30.130] ssm2_init
[00:25:30.150] ssm2_init
[00:25:30.160] ssm2_init
[00:25:30.340] kernel get version
[00:25:30.861] validating denso kernel ram area addr: FFFF0000 len: 0008
[00:25:58.150] ssm2_init
[00:25:58.370] ssm2_init
[00:25:58.390] ssm2_init
[00:25:58.400] ssm2_init
[00:25:58.420] ssm2_init
[00:25:58.440] ssm2_init
[00:25:58.450] ssm2_init
[00:25:58.470] ssm2_init
[00:25:58.490] ssm2_init
[00:25:58.501] ssm2_init
[00:25:58.691] kernel get version
[00:25:59.212] validating denso kernel ram area addr: FFFF0000 len: 0008
does any one have any idea?...
zigzagzok
Postby Jeramie » Fri Nov 17, 2006 4:48 am
I had trouble with my drivers when trying to uninstall.
I had to uninstall, then remove drivers. Then reinstalled, but still wouldn't work so I uninstalled again, removed the FTDI drivers, deled openecu folder, then went into hardware manager and deleted the com port. Then reinstalled and everything was working fine.?
Jeramie
