Trouble reading ROM on 2003 WRX
Postby cboles » Mon Jan 16, 2006 9:19 pm
trying to get to the patch tonight...
Postby cboles » Tue Jan 17, 2006 4:29 pm
give this version of ecuflash a try. it has a correct 04+ bootloader checksum for the kernel, although no 02/03 bootloader code that I have seen in the TPU seems to care. it's worth a shot though.
colby
ecuflash.rar
ecuflash version for testing only!!!
(53.93 KiB) Downloaded 596 times
Postby Freon » Tue Jan 17, 2006 4:42 pm
I'll give it a shot once I can get my hands on the car in question.
Postby ride5000 » Thu Jan 19, 2006 8:50 am
downloaded.
i'll be trying this out after lunch.
ken
ride5000
Postby ride5000 » Thu Jan 19, 2006 2:43 pm
unfortunately, again no success.
0   0.02141613   ecuflash2.exe   IRP_MJ_CREATE   VCP0   SUCCESS   Options: Open
1   0.00001173   ecuflash2.exe   IOCTL_SERIAL_SET_QUEUE_SIZE   VCP0   SUCCESS   InSize: 16384 OutSize: 16384
2   0.00000223   ecuflash2.exe   IOCTL_SERIAL_GET_BAUD_RATE   VCP0   SUCCESS
3   0.00000223   ecuflash2.exe   IOCTL_SERIAL_GET_LINE_CONTROL   VCP0   SUCCESS
4   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_CHARS   VCP0   SUCCESS
5   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_HANDFLOW   VCP0   SUCCESS
6   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_BAUD_RATE   VCP0   SUCCESS
7   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_LINE_CONTROL   VCP0   SUCCESS
8   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_CHARS   VCP0   SUCCESS
9   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_HANDFLOW   VCP0   SUCCESS
10   0.00178123   ecuflash2.exe   IOCTL_SERIAL_SET_BAUD_RATE   VCP0   SUCCESS   Rate: 4800
11   0.00288305   ecuflash2.exe   IOCTL_SERIAL_CLR_RTS   VCP0   SUCCESS
12   0.00297887   ecuflash2.exe   IOCTL_SERIAL_SET_DTR   VCP0   SUCCESS
13   0.00306212   ecuflash2.exe   IOCTL_SERIAL_SET_LINE_CONTROL   VCP0   SUCCESS   StopBits: 1 Parity: NONE WordLength: 8
14   0.00000223   ecuflash2.exe   IOCTL_SERIAL_SET_CHAR   VCP0   SUCCESS   EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
15   0.00286657   ecuflash2.exe   IOCTL_SERIAL_SET_HANDFLOW   VCP0   SUCCESS   Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
16   0.00000223   ecuflash2.exe   IOCTL_SERIAL_SET_TIMEOUTS   VCP0   SUCCESS   RI:-1 RM:0 RC:0 WM:50 WC:0
17   0.00294842   ecuflash2.exe   IOCTL_SERIAL_SET_WAIT_MASK   VCP0   SUCCESS   Mask: CTS DSR
18   0.00000279   ecuflash2.exe   IRP_MJ_FLUSH_BUFFERS   VCP0   SUCCESS
19   0.00295708   ecuflash2.exe   IOCTL_SERIAL_SET_DTR   VCP0   SUCCESS
20   0.00000419   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
21   0.00298111   ecuflash2.exe   IOCTL_SERIAL_SET_DTR   VCP0   SUCCESS
22   0.00001090   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
23   0.00000419   ecuflash2.exe   IOCTL_SERIAL_SET_QUEUE_SIZE   VCP0   SUCCESS   InSize: 16384 OutSize: 16384
24   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_BAUD_RATE   VCP0   SUCCESS
25   0.00000251   ecuflash2.exe   IOCTL_SERIAL_GET_LINE_CONTROL   VCP0   SUCCESS
26   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_CHARS   VCP0   SUCCESS
27   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_HANDFLOW   VCP0   SUCCESS
28   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_BAUD_RATE   VCP0   SUCCESS
29   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_LINE_CONTROL   VCP0   SUCCESS
30   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_CHARS   VCP0   SUCCESS
31   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_HANDFLOW   VCP0   SUCCESS
32   0.00329092   ecuflash2.exe   IOCTL_SERIAL_SET_BAUD_RATE   VCP0   SUCCESS   Rate: 39473
33   0.00290177   ecuflash2.exe   IOCTL_SERIAL_CLR_RTS   VCP0   SUCCESS
34   0.00297915   ecuflash2.exe   IOCTL_SERIAL_SET_DTR   VCP0   SUCCESS
35   0.00297664   ecuflash2.exe   IOCTL_SERIAL_SET_LINE_CONTROL   VCP0   SUCCESS   StopBits: 1 Parity: NONE WordLength: 8
36   0.00000223   ecuflash2.exe   IOCTL_SERIAL_SET_CHAR   VCP0   SUCCESS   EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
37   0.00295289   ecuflash2.exe   IOCTL_SERIAL_SET_HANDFLOW   VCP0   SUCCESS   Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
38   0.00000223   ecuflash2.exe   IOCTL_SERIAL_SET_TIMEOUTS   VCP0   SUCCESS   RI:-1 RM:0 RC:0 WM:50 WC:0
39   0.00294646   ecuflash2.exe   IOCTL_SERIAL_SET_WAIT_MASK   VCP0   SUCCESS   Mask: CTS DSR
40   0.00000279   ecuflash2.exe   IRP_MJ_FLUSH_BUFFERS   VCP0   SUCCESS
41   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
42   0.00585857   ecuflash2.exe   IRP_MJ_WRITE   VCP0   SUCCESS   Length 6: BE EF 00 01 21 CF
43   0.00001090   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 1: 3C
44   0.00001257   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 3: CE 00 FC
45   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
46   0.00000419   ecuflash2.exe   IOCTL_SERIAL_SET_QUEUE_SIZE   VCP0   SUCCESS   InSize: 16384 OutSize: 16384
47   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_BAUD_RATE   VCP0   SUCCESS
48   0.00000223   ecuflash2.exe   IOCTL_SERIAL_GET_LINE_CONTROL   VCP0   SUCCESS
49   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_CHARS   VCP0   SUCCESS
50   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_HANDFLOW   VCP0   SUCCESS
51   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_BAUD_RATE   VCP0   SUCCESS
52   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_LINE_CONTROL   VCP0   SUCCESS
53   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_CHARS   VCP0   SUCCESS
54   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_HANDFLOW   VCP0   SUCCESS
55   0.00299396   ecuflash2.exe   IOCTL_SERIAL_SET_BAUD_RATE   VCP0   SUCCESS   Rate: 9600
56   0.00297412   ecuflash2.exe   IOCTL_SERIAL_CLR_RTS   VCP0   SUCCESS
57   0.00297719   ecuflash2.exe   IOCTL_SERIAL_SET_DTR   VCP0   SUCCESS
58   0.00297608   ecuflash2.exe   IOCTL_SERIAL_SET_LINE_CONTROL   VCP0   SUCCESS   StopBits: 1 Parity: NONE WordLength: 8
59   0.00000223   ecuflash2.exe   IOCTL_SERIAL_SET_CHAR   VCP0   SUCCESS   EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
60   0.00202819   ecuflash2.exe   IOCTL_SERIAL_SET_HANDFLOW   VCP0   SUCCESS   Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
61   0.00000223   ecuflash2.exe   IOCTL_SERIAL_SET_TIMEOUTS   VCP0   SUCCESS   RI:-1 RM:0 RC:0 WM:50 WC:0
62   0.00287104   ecuflash2.exe   IOCTL_SERIAL_SET_WAIT_MASK   VCP0   SUCCESS   Mask: CTS DSR
63   0.00000279   ecuflash2.exe   IRP_MJ_FLUSH_BUFFERS   VCP0   SUCCESS
64   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
65   0.00280930   ecuflash2.exe   IOCTL_SERIAL_SET_DTR   VCP0   SUCCESS
66   0.00241371   ecuflash2.exe   IOCTL_SERIAL_CLR_DTR   VCP0   SUCCESS
67   0.00309369   ecuflash2.exe   IOCTL_SERIAL_SET_DTR   VCP0   SUCCESS
68   0.00678718   ecuflash2.exe   IRP_MJ_WRITE   VCP0   SUCCESS   Length 3: 4D FF B4
69   0.00001006   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
70   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
71   0.00000503   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 3: 4D FF B4
72   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
73   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 3: 4D 00 B3
74   1.46375782   ecuflash2.exe   IRP_MJ_WRITE   VCP0   SUCCESS   Length 1527: 53 02 00 00 05 F0 F5 8D 39 41 65 65 84 41 65 65 6C 66 2A 35 40
75   0.00001257   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 1397: 53 02 00 00 05 F0 F5 8D 39 41 65 65 84 41 65 65 6C 66 2A 35 40
76   0.00000335   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 16: CB 52 5D 64 6C 72 F0 65 AD BF 67 67 99 82 B2 71
77   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
78   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 15: 64 B0 6A 72 D8 72 F8 B2 E5 72 09 30 25 72 81
79   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
80   0.00000782   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 15: 72 98 70 25 82 B2 82 8C 6D 61 BA BA 82 8C 6D
81   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 16: 63 BA BA 82 B2 71 66 52 41 6D 62 52 4F 6D 62 72
82   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
83   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 15: 70 65 6D 82 8A 6D 61 82 8B 6D 63 F1 51 72 F0
84   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 15: E6 85 72 C1 6D 63 72 CF 6D 63 72 F0 C8 FD 72
85   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
86   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 16: C1 6D 61 72 CF 6D 61 72 75 65 64 F3 91 70 45 82
87   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 15: B2 71 64 82 85 6D 61 82 85 6D 63 82 2B 72 F9
88   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
89   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 7: 6D 61 70 25 82 B2 46
90   0.00000363   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
91   0.00000391   ecuflash2.exe   IOCTL_SERIAL_SET_QUEUE_SIZE   VCP0   SUCCESS   InSize: 16384 OutSize: 16384
92   0.00000223   ecuflash2.exe   IOCTL_SERIAL_GET_BAUD_RATE   VCP0   SUCCESS
93   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_LINE_CONTROL   VCP0   SUCCESS
94   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_CHARS   VCP0   SUCCESS
95   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_HANDFLOW   VCP0   SUCCESS
96   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_BAUD_RATE   VCP0   SUCCESS
97   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_LINE_CONTROL   VCP0   SUCCESS
98   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_CHARS   VCP0   SUCCESS
99   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_HANDFLOW   VCP0   SUCCESS
100   0.00316465   ecuflash2.exe   IOCTL_SERIAL_SET_BAUD_RATE   VCP0   SUCCESS   Rate: 39473
101   0.00297691   ecuflash2.exe   IOCTL_SERIAL_CLR_RTS   VCP0   SUCCESS
102   0.00297747   ecuflash2.exe   IOCTL_SERIAL_SET_DTR   VCP0   SUCCESS
103   0.00305206   ecuflash2.exe   IOCTL_SERIAL_SET_LINE_CONTROL   VCP0   SUCCESS   StopBits: 1 Parity: NONE WordLength: 8
104   0.00000223   ecuflash2.exe   IOCTL_SERIAL_SET_CHAR   VCP0   SUCCESS   EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
105   0.00287578   ecuflash2.exe   IOCTL_SERIAL_SET_HANDFLOW   VCP0   SUCCESS   Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
106   0.00000223   ecuflash2.exe   IOCTL_SERIAL_SET_TIMEOUTS   VCP0   SUCCESS   RI:-1 RM:0 RC:0 WM:50 WC:0
107   0.00294786   ecuflash2.exe   IOCTL_SERIAL_SET_WAIT_MASK   VCP0   SUCCESS   Mask: CTS DSR
108   0.00000251   ecuflash2.exe   IRP_MJ_FLUSH_BUFFERS   VCP0   SUCCESS
109   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
110   0.00069087   ecuflash2.exe   IRP_MJ_WRITE   VCP0   SUCCESS   Length 6: BE EF 00 01 01 AF
111   0.00000670   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 1: 3C
112   0.00000363   ecuflash2.exe   IRP_MJ_CLEANUP   VCP0   SUCCESS
113   0.01581402   ecuflash2.exe   IRP_MJ_CLOSE   VCP0   SUCCESS
also tried it with the my04+ option:
0   0.02238804   ecuflash2.exe   IRP_MJ_CREATE   VCP0   SUCCESS   Options: Open
1   0.00001732   ecuflash2.exe   IOCTL_SERIAL_SET_QUEUE_SIZE   VCP0   SUCCESS   InSize: 16384 OutSize: 16384
2   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_BAUD_RATE   VCP0   SUCCESS
10   0.00178570   ecuflash2.exe   IOCTL_SERIAL_SET_BAUD_RATE   VCP0   SUCCESS   Rate: 4800
11   0.00288528   ecuflash2.exe   IOCTL_SERIAL_CLR_RTS   VCP0   SUCCESS
12   0.00297915   ecuflash2.exe   IOCTL_SERIAL_SET_DTR   VCP0   SUCCESS
13   0.00306044   ecuflash2.exe   IOCTL_SERIAL_SET_LINE_CONTROL   VCP0   SUCCESS   StopBits: 1 Parity: NONE WordLength: 8
15   0.00286824   ecuflash2.exe   IOCTL_SERIAL_SET_HANDFLOW   VCP0   SUCCESS   Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
17   0.00294702   ecuflash2.exe   IOCTL_SERIAL_SET_WAIT_MASK   VCP0   SUCCESS   Mask: CTS DSR
19   0.00295736   ecuflash2.exe   IOCTL_SERIAL_SET_DTR   VCP0   SUCCESS
21   0.00295596   ecuflash2.exe   IOCTL_SERIAL_CLR_DTR   VCP0   SUCCESS
22   0.00001117   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
23   0.00000447   ecuflash2.exe   IOCTL_SERIAL_SET_QUEUE_SIZE   VCP0   SUCCESS   InSize: 16384 OutSize: 16384
24   0.00000223   ecuflash2.exe   IOCTL_SERIAL_GET_BAUD_RATE   VCP0   SUCCESS
25   0.00000223   ecuflash2.exe   IOCTL_SERIAL_GET_LINE_CONTROL   VCP0   SUCCESS
27   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_HANDFLOW   VCP0   SUCCESS
32   0.00272102   ecuflash2.exe   IOCTL_SERIAL_SET_BAUD_RATE   VCP0   SUCCESS   Rate: 39473
33   0.00297468   ecuflash2.exe   IOCTL_SERIAL_CLR_RTS   VCP0   SUCCESS
34   0.00297747   ecuflash2.exe   IOCTL_SERIAL_SET_DTR   VCP0   SUCCESS
35   0.00297636   ecuflash2.exe   IOCTL_SERIAL_SET_LINE_CONTROL   VCP0   SUCCESS   StopBits: 1 Parity: NONE WordLength: 8
36   0.00000251   ecuflash2.exe   IOCTL_SERIAL_SET_CHAR   VCP0   SUCCESS   EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
37   0.00295373   ecuflash2.exe   IOCTL_SERIAL_SET_HANDFLOW   VCP0   SUCCESS   Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
39   0.00294563   ecuflash2.exe   IOCTL_SERIAL_SET_WAIT_MASK   VCP0   SUCCESS   Mask: CTS DSR
41   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
42   0.00364376   ecuflash2.exe   IRP_MJ_WRITE   VCP0   SUCCESS   Length 6: BE EF 00 01 21 CF
43   0.00000922   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 1: 3C
44   0.00000922   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 3: CE 00 FC
47   0.00000223   ecuflash2.exe   IOCTL_SERIAL_GET_BAUD_RATE   VCP0   SUCCESS
50   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_HANDFLOW   VCP0   SUCCESS
55   0.00238215   ecuflash2.exe   IOCTL_SERIAL_SET_BAUD_RATE   VCP0   SUCCESS   Rate: 4800
56   0.00297664   ecuflash2.exe   IOCTL_SERIAL_CLR_RTS   VCP0   SUCCESS
57   0.00297775   ecuflash2.exe   IOCTL_SERIAL_SET_DTR   VCP0   SUCCESS
58   0.00297636   ecuflash2.exe   IOCTL_SERIAL_SET_LINE_CONTROL   VCP0   SUCCESS   StopBits: 1 Parity: NONE WordLength: 8
60   0.00302860   ecuflash2.exe   IOCTL_SERIAL_SET_HANDFLOW   VCP0   SUCCESS   Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
61   0.00000196   ecuflash2.exe   IOCTL_SERIAL_SET_TIMEOUTS   VCP0   SUCCESS   RI:-1 RM:0 RC:0 WM:50 WC:0
62   0.00287215   ecuflash2.exe   IOCTL_SERIAL_SET_WAIT_MASK   VCP0   SUCCESS   Mask: CTS DSR
63   0.00000251   ecuflash2.exe   IRP_MJ_FLUSH_BUFFERS   VCP0   SUCCESS
64   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
65   0.00116104   ecuflash2.exe   IRP_MJ_WRITE   VCP0   SUCCESS   Length 6: 80 10 F0 01 81 02
66   0.00000587   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
67   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
68   0.00000391   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 1: 80
69   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 1: 10
70   0.00000223   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
71   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 1: F0
72   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 1: 01
73   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 1: 81
74   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 1: 02
75   0.00000223   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
76   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
78   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
79   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
80   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
81   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
82   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
83   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
84   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
86   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
87   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
89   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
90   0.00000615   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
91   0.00000419   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
92   0.00000391   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
93   0.00000503   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
94   0.00000531   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
95   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
96   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
97   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
98   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
99   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
100   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
101   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
102   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
103   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
104   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
105   0.00000391   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
106   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
107   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
108   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
109   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
110   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
111   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
112   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
113   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
114   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
115   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
116   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
117   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
118   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
119   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
120   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
121   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
122   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
123   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
124   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
125   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
126   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
127   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
128   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
129   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
130   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
131   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
132   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
133   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
134   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
135   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
136   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
137   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
138   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
139   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
140   0.00000503   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
141   0.00000363   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
142   0.00000587   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
143   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
144   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
145   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
146   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
147   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
148   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
149   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
150   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
151   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
152   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
153   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
154   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
155   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
156   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
157   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
158   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
159   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
160   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
161   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
162   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
163   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
164   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
165   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
166   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
167   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
168   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
169   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
170   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
171   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
172   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
173   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
174   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
175   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
176   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
177   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
178   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
179   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
180   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
181   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
182   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
183   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
184   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
185   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
186   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
187   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
188   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
189   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
190   0.00000419   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
191   0.00000559   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
192   0.00000531   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
193   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
194   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
195   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
196   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
197   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
198   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
199   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
200   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
201   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
202   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
203   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
204   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
205   0.00001173   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
206   0.00000363   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
207   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
208   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
209   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
210   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
211   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
212   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
213   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
214   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
215   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
216   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
217   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
218   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
219   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
220   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
221   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
222   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
223   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
224   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
225   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
226   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
227   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
228   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
229   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
230   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
231   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
232   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
233   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
234   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
235   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
236   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
237   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
238   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
239   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
240   0.00000419   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
241   0.00000559   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
242   0.00000447   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
243   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
244   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
245   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
246   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
247   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
248   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
249   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
250   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
251   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
252   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
253   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
254   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
255   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
256   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
257   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
258   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
259   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
260   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
261   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
262   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
263   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
264   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
265   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
266   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
267   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
268   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
269   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
270   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
271   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
272   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
273   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
274   0.00000279   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
275   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
276   0.00000363   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
277   0.00000391   ecuflash2.exe   IOCTL_SERIAL_SET_QUEUE_SIZE   VCP0   SUCCESS   InSize: 16384 OutSize: 16384
278   0.00000223   ecuflash2.exe   IOCTL_SERIAL_GET_BAUD_RATE   VCP0   SUCCESS
279   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_LINE_CONTROL   VCP0   SUCCESS
280   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_CHARS   VCP0   SUCCESS
281   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_HANDFLOW   VCP0   SUCCESS
282   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_BAUD_RATE   VCP0   SUCCESS
283   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_LINE_CONTROL   VCP0   SUCCESS
284   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_CHARS   VCP0   SUCCESS
285   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_HANDFLOW   VCP0   SUCCESS
286   0.00266738   ecuflash2.exe   IOCTL_SERIAL_SET_BAUD_RATE   VCP0   SUCCESS   Rate: 15625
287   0.00297580   ecuflash2.exe   IOCTL_SERIAL_CLR_RTS   VCP0   SUCCESS
288   0.00297803   ecuflash2.exe   IOCTL_SERIAL_SET_DTR   VCP0   SUCCESS
289   0.00297664   ecuflash2.exe   IOCTL_SERIAL_SET_LINE_CONTROL   VCP0   SUCCESS   StopBits: 1 Parity: NONE WordLength: 8
290   0.00000223   ecuflash2.exe   IOCTL_SERIAL_SET_CHAR   VCP0   SUCCESS   EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
291   0.00302664   ecuflash2.exe   IOCTL_SERIAL_SET_HANDFLOW   VCP0   SUCCESS   Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
292   0.00000223   ecuflash2.exe   IOCTL_SERIAL_SET_TIMEOUTS   VCP0   SUCCESS   RI:-1 RM:0 RC:0 WM:50 WC:0
293   0.00287215   ecuflash2.exe   IOCTL_SERIAL_SET_WAIT_MASK   VCP0   SUCCESS   Mask: CTS DSR
294   0.00000279   ecuflash2.exe   IRP_MJ_FLUSH_BUFFERS   VCP0   SUCCESS
295   0.00000307   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
296   0.01498738   ecuflash2.exe   IRP_MJ_WRITE   VCP0   SUCCESS   Length 13: 80 10 F0 08 34 02 00 00 04 00 00 08 CA
297   0.00001090   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 1: 00
298   0.00001145   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 3: 00 00 00
299   0.00000223   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
300   0.00000363   ecuflash2.exe   IOCTL_SERIAL_SET_QUEUE_SIZE   VCP0   SUCCESS   InSize: 16384 OutSize: 16384
301   0.00000251   ecuflash2.exe   IOCTL_SERIAL_GET_BAUD_RATE   VCP0   SUCCESS
302   0.00000223   ecuflash2.exe   IOCTL_SERIAL_GET_LINE_CONTROL   VCP0   SUCCESS
303   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_CHARS   VCP0   SUCCESS
304   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_HANDFLOW   VCP0   SUCCESS
305   0.00000196   ecuflash2.exe   IOCTL_SERIAL_GET_BAUD_RATE   VCP0   SUCCESS
306   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_LINE_CONTROL   VCP0   SUCCESS
307   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_CHARS   VCP0   SUCCESS
308   0.00000168   ecuflash2.exe   IOCTL_SERIAL_GET_HANDFLOW   VCP0   SUCCESS
309   0.00294423   ecuflash2.exe   IOCTL_SERIAL_SET_BAUD_RATE   VCP0   SUCCESS   Rate: 4800
310   0.00297552   ecuflash2.exe   IOCTL_SERIAL_CLR_RTS   VCP0   SUCCESS
311   0.00297775   ecuflash2.exe   IOCTL_SERIAL_SET_DTR   VCP0   SUCCESS
312   0.00297580   ecuflash2.exe   IOCTL_SERIAL_SET_LINE_CONTROL   VCP0   SUCCESS   StopBits: 1 Parity: NONE WordLength: 8
313   0.00000223   ecuflash2.exe   IOCTL_SERIAL_SET_CHAR   VCP0   SUCCESS   EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
314   0.00295317   ecuflash2.exe   IOCTL_SERIAL_SET_HANDFLOW   VCP0   SUCCESS   Shake:1 Replace:80000000 XonLimit:2048 XoffLimit:512
315   0.00000223   ecuflash2.exe   IOCTL_SERIAL_SET_TIMEOUTS   VCP0   SUCCESS   RI:-1 RM:0 RC:0 WM:50 WC:0
316   0.00294702   ecuflash2.exe   IOCTL_SERIAL_SET_WAIT_MASK   VCP0   SUCCESS   Mask: CTS DSR
317   0.00000223   ecuflash2.exe   IRP_MJ_FLUSH_BUFFERS   VCP0   SUCCESS
318   0.00000251   ecuflash2.exe   IRP_MJ_READ   VCP0   SUCCESS   Length 0:
319   0.00000335   ecuflash2.exe   IRP_MJ_CLEANUP   VCP0   SUCCESS
320   0.01373527   ecuflash2.exe   IRP_MJ_CLOSE   VCP0   SUCCESS
this time the relays never stopped cycling.
ride5000
Postby dust12 » Thu May 04, 2006 6:40 pm
I recently had a chance to try out the latest release and it now works on my car. Thanks Colby!
dust12
Postby cboles » Thu May 04, 2006 6:41 pm
great!
