1452 byte kernel read.
Connect the green test mode connector under your dash, turn your ignition to the
'ON' position,then quickly, press the D key to dump all of ecu memory,
or any other key to cancel.
denso02_bootloader_cmd_start
kernel flash disable
rkrv: preamble 1 error
ride5000 wrote:tried it out this morning and got this:
- Code: Select all
fuel pump and fans never stopped cycling.
i'm going to try the gui version for the hell of it in a few minutes. i have an 03.
ken
ride5000 wrote:no, i just connected my "green" terminals together. i will crawl under the dash again today to check if i have other terminals.
the gui version did not work, as expected.
cboles wrote:just curious: have you tried reading out your ecu using the 04 mode? it might just work...
colby
ride5000 wrote:cboles wrote:just curious: have you tried reading out your ecu using the 04 mode? it might just work...
colby
i did indeed try that colby, unfortunately.
i am off to try the CLI version (0.91) since crazymikie said he had slightly better luck with it. who knows?
ken
Users browsing this forum: No registered users and 14 guests
