need help selctiong proper rom file 2003 evo8 usdm
Postby boostedevo8 » Tue Aug 14, 2012 6:23 am
Hi im haveing trouble selcting the correct rom file for my car.I have a usdm 2003 evo8 and the rom files i found for 2003 is evo 7.Im confused and they have 5 different 2004 evo8 usdm models to chose from could somebody please help. I know this may be answered somewhere but counldnt find help thanks
boostedevo8
Re: need help selctiong proper rom file 2003 evo8 usdm
Postby 06rexwagon » Tue Aug 21, 2012 7:03 pm
evolutionm.net
look at your stock rom id. You can't just flash another rom over without copying the immobilizer code into it.
06rexwagon
Postby boostedevo8 » Thu Aug 23, 2012 7:59 am
Ok I understand u the car has some mods done to it also.like bigger cams and turbo will it still be under the stock I'd number also.Are do I have to find out what file they use cause when I purchased the car I was told jms racing tuned it and a guy name kazz.So how do I pull that rom file from the ecu thanks.
boostedevo8
Postby 06rexwagon » Thu Aug 23, 2012 12:00 pm
use a tactrix cable and ecuflash to read it. If it's locked use the unlock tool from aktivematrix
06rexwagon
Postby boostedevo8 » Thu Aug 23, 2012 12:06 pm
I got the cable and I connected it but couldn't click the read folder on ecu flash could u tell me what I did wrong do I need to find the proper files first if so how will I do that
boostedevo8
Postby 06rexwagon » Thu Aug 23, 2012 12:24 pm
What happens when you hit read? Does it bring up the read templates?
06rexwagon
Postby boostedevo8 » Thu Aug 23, 2012 12:36 pm
I click the read template and it does nothing
boostedevo8
Postby ashleyco » Tue Dec 10, 2013 10:42 pm
ashleyco
Return to OpenECU Software
