re: map editing
re: map editing
Postby wcassar » Wed Dec 07, 2011 1:38 pm
Hi all, I have installed the ecuflash 1.29a version and yes, I have succeed in connecteing with the evo 7 ecu and read the map.
One problem has arised, I cannot see the map itself.
The user is set to developer already.
regards
wcassar
Re: re: map editing
Postby todd-w » Wed Dec 07, 2011 2:40 pm
you need the xml 98640014 and evo7 base xml most likely should be on here somewhere
todd-w
Re: re: map editing
Postby todd-w » Wed Dec 07, 2011 2:51 pm
viewtopic.php?f=55&t=4982&p=24773&hilit=evo7+jdm+definition#p24773
xml above and base xml attached save to rommetdata/mitsi/evo
evo7base.xml
(26.21 KiB) Downloaded 992 times
todd-w
Re: re: map editing
Postby wcassar » Fri Dec 09, 2011 11:52 am
thats fine i read well and can edit maps....
how can I eliminate the error P0136 error fro periphery?
regards
wcassar
Re: re: map editing
Postby todd-w » Fri Dec 09, 2011 1:29 pm
what car is the ecu running ??
log the front o2 sensor with evoscan make sure its working
todd-w
Re: re: map editing
Postby wcassar » Sat Dec 10, 2011 11:03 am
I m running a 4g63 evo 1-3 engine with the evo7 ecu.
wcassar
Re: re: map editing
Postby todd-w » Sun Dec 18, 2011 1:21 pm
is the eng in a 1-3 ???
try disable it in the ecu periphery 2 (FCA) change bit 04 to 0 , something strange there though as a jdm 7 using 98640014 rom never had rear o2 so ecu shouldnt be looking for a signal you can use 90550001 rom ,no rear o2 or immobiliser
ps you certain its not p0135 fr o2 heater circuit
Anyway as you dont have 4 wire o2 change periphery FAA bits bit14 (fr o2 heater circuit ) to 0
todd-w
Return to OpenECU Software
