'01 Eclipse GT m/t
'01 Eclipse GT m/t
Postby twistedturbo6692 » Mon Jul 25, 2011 9:50 am
Have the Openport 2.0, mitsu cable and Ecuflash downloaded. When I retrieve the factory files everything is good but I get a message basically saying it cannot be modified?! Any suggestions or am I dead in the water?
Ray
twistedturbo6692
Re: '01 Eclipse GT m/t
Postby todd-w » Mon Jul 25, 2011 1:14 pm
can you attach the rom here ??
todd-w
Postby twistedturbo6692 » Fri Jul 29, 2011 8:12 am
Here you are.
01_ECLIPSE_GT_MT_96720008.hex
(256 KiB) Downloaded 1097 times
twistedturbo6692
Postby And » Tue Aug 02, 2011 4:32 am
it might be the memory model or the flash method might not be correct for the ecu,
acording to the xml its a SH7052 and using the mitsukernel, could be worth looking in the ecu case to make sure its not a different processor
Andy
And
Postby twistedturbo6692 » Mon Aug 08, 2011 6:44 am
Thanks Andy! I was wondering if pulling same year ECU off a different Eclipse/Stratus might work so long as its not coded to the other modules on the vehicle.
Ray
twistedturbo6692
Postby twistedturbo6692 » Wed Sep 28, 2011 3:22 am
Got everything going, the battery voltage was actually not where it should have been during the reading/write process. The only obstacle now is the immobilizer and how to delete it. Any clues, anyone?
twistedturbo6692
Postby And » Wed Sep 28, 2011 3:53 am
you should see it in the periphery bits under FAA bit 3 i've attached the above rom with the immob disabled
01_ECLIPSE_GT_MT_96720008_mod.hex
(256 KiB) Downloaded 1009 times
And
Postby twistedturbo6692 » Fri Sep 30, 2011 4:24 am
Thank you very very much Andy! :D
Ray
twistedturbo6692
Postby twistedturbo6692 » Sat Oct 01, 2011 12:35 pm
Hey Andy, I flashed that ROM to the vehicle and it still won't start. I used my scanner and I do get a P1610 immobilizer code, apparently it is still active any other ideas?
Ray :?:
twistedturbo6692
Postby And » Sun Oct 02, 2011 12:27 am
hi
i've tried editing the periphery bits again, if you want to try this
01_ECLIPSE_GT_MT_96720008_mod2.hex
(256 KiB) Downloaded 982 times
And
Postby twistedturbo6692 » Sun Oct 02, 2011 3:13 pm
Hey Andy thanks for the file but no luck. I finally realized what you were talking about when you said periphery and bit 3. When I open up ECUflash none of my periphery tables are displayed even though I've copied and pasted the periphery stuff from an evo7base20081101.xml to my 96720008.xml. Obviously I am doing something wrong. Your help is greatly appreciated.
Ray
twistedturbo6692
Postby And » Sun Oct 02, 2011 10:55 pm
here's my evo 7 base that contains the information
evo7base.xml
(52.72 KiB) Downloaded 993 times
And
Postby twistedturbo6692 » Mon Oct 03, 2011 3:50 am
Thanks Andy, I will try that and let you know how it goes.
Ray
twistedturbo6692
Postby twistedturbo6692 » Sat Oct 08, 2011 2:49 pm
Andy I got the periphery data pasted in my 96720008 xml and now its displayed in the hex file. Under periphery 0 (FAA) bit 3 I see the immobilizer enable/disable, I've flashed it just that way with no luck. The immobilizer is still appears to be intervening. I'm confused. :|
many thanks,
Ray
twistedturbo6692
Postby twistedturbo6692 » Wed Oct 12, 2011 4:48 am
Update, I got everything to work!!! I wiped everything out and re-installed ECUflash on the old laptop and made the necessary pasting. Thanks for all your help Andy.
Ray
twistedturbo6692
Return to OpenECU Software
