ECUFLASH XML Definitions
Postby New2Scoobs » Thu Apr 27, 2006 2:59 am
So do we need to know all 3 offsets to define a single 3d map (e.g Main ignition timing map) with ECUFLASH?
I looked at the XML sample file you suggested Colby and it appears to me as though we cant create an XML definition file with just a single offset (as we can in ECUEDIT) - Or am i missing something? :oops:
If my observations are correct, how do I obtain the other 2 offsets needed to define a 3d map?
Postby JRSCCivic98 » Thu Apr 27, 2006 5:47 am
Can't we just use xmlwrite to create the xmls for ecuFlash as well? The current version of xmlwrite supports both singlepoint and multipoint values.
Postby xswrex » Thu Apr 27, 2006 10:13 pm
ecuflash and enginuity xml formats are quite similar.
I guess i could add another output format but currently i am busy with something more important
xswrex
Return to OpenECU Software
