I can't open TME ecu
Postby zambelly » Tue Jul 27, 2010 6:10 am
have been with TME ECU MR514364. I bought OpenPort 1.3 cable. I can not read the ECU. I tried with 2.7 and Evoscan ecuflash 1.42, but did not work. Evo 8 at the cable I can read and write. Could someone help me?
zambelly
Re: I can't open TME ecu
Postby radsdau » Tue Jul 27, 2010 3:24 pm
Try ECU Unlocker (only works for EVO).
Postby Michal_6 » Thu Jul 29, 2010 12:59 pm
HI, I've got Evo 6 TME 2001, ECU cpu MH7203FA. I also tied several times but without any success, even with ecu unlock tool started.
My log looks as follows:
(1.st test Evo 5/6, 2nd test evo 6.5)
[23:07:18.252] EcuFlash Version 1.42.2595
[23:07:18.252] OS Version Windows Vista
[23:07:18.252] Qt Version 4.5.0
[23:07:18.263] 56 memory models read.
[23:07:18.264] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[23:07:18.540] 343 ROM metadata models scanned.
[23:07:18.540] checksum module "subarudbw" loaded.
[23:07:18.540] checksum module "mitsucan" loaded.
[23:07:18.540] flashing tool "wrx02" loaded.
[23:07:18.540] flashing tool "wrx04" loaded.
[23:07:18.541] flashing tool "sti04" loaded.
[23:07:18.541] flashing tool "sti05" loaded.
[23:07:18.541] flashing tool "mitsukernel" loaded.
[23:07:18.541] flashing tool "mitsukernelocp" loaded.
[23:07:18.541] flashing tool "mitsubootloader" loaded.
[23:07:18.542] flashing tool "shbootmode" loaded.
[23:07:18.543] flashing tool "shaudmode" loaded.
[23:07:18.543] flashing tool "subarucan" loaded.
[23:07:18.544] flashing tool "mitsucan" loaded.
[23:07:21.893] Using interface OpenPort 1.3 Universal TX27F9cy9699f4d5b4eb04ded73f2dd757acafd543097b09
[23:07:23.886] sending init sequence 2
[23:07:25.900] interface close
[23:07:30.785] Using interface OpenPort 1.3 Universal TX27F9cy9699f4d5b4eb04ded73f2dd757acafd543097b09
[23:07:32.797] sending init sequence 2
[23:07:34.810] interface close
Do you have any idea what to do to make it working ?
Michal_6
Postby ptharris » Thu Jul 29, 2010 9:48 pm
you have the wrong cable!!!!!
You need the Open port 2 to flash the TME ecu
ptharris
Postby zambelly » Fri Jul 30, 2010 6:15 am
My problem is this!
I have a bad cable?
Openport2.0 I need a cable?
zambelly
Postby Evo's are cool » Tue Sep 07, 2010 2:43 am
I have an OP 2.0 cable and get the exact same problem as original poster!! I've checked all the wiring from the obd2 connector and 12pin connector, this is fine. What else should I check ? I'm using 1.43.300 and OP2.0.
Evo's are cool
Return to OpenECU Software
