ECUFlash 1.43 beta ERR_TIMEOUT during test write
Postby Digitalfiend » Tue Jul 06, 2010 8:36 pm
I've recently switched from ATR to ECUFlash and os-tuning for learning purposes (more tables, disassembling my own ROM in IDA, etc) and encountered my first "oh crap" moment while flashing - well, test writing actually.
[19:08:37.389] kernel write flash buffer addr: 000CC000 len: 00000800
[19:08:37.498] kernel write flash buffer addr: 000CC800 len: 00000800
[19:08:37.608] kernel validate flash addr: 000CC000 len: 00001000 crc32: 71f07369
[19:08:37.623] kernel write flash buffer addr: 000CD000 len: 00000800
[19:08:37.717] kernel write flash buffer addr: 000CD800 len: 00000800
[19:08:37.810] kernel validate flash addr: 000CD000 len: 00001000 crc32: 2af11b5f
[19:08:37.826] kernel write flash buffer addr: 000CE000 len: 00000800
[19:08:37.966] kernel write flash buffer addr: 000CE800 len: 00000800
[19:08:40.010] J2534 error [ERR_TIMEOUT].
[19:08:40.010] reading kernel comm stats
[19:08:40.026] kernel write flash buffer addr: 000CE800 len: 00000800
[19:08:40.119] kernel validate flash addr: 000CE000 len: 00001000 crc32: 4846cf4a
[19:08:40.135] failed to validate flash buffer!
[19:08:40.135] failure in flashing block[19:08:40.135] kernel flash disable
[19:08:40.150] interface close
[19:08:40.166] interface close
I re-ran the test-write and it passed, after which I performed an actually reflash, which succeeded.
Now my concern is, would this timeout error have "bricked" the ECU or is it possible to recover from such an error by attempting to reflash again? Therefore, does any error in reflashing always result in an unflashable ECU?
I've flashed my car with my AP around 30-40 times and have never had an error. This was my 6th reflash using ECUFlash. Could this be a beta issue, possibly related to the new USB driver?
I'm using ECUFlash 1.43.3000 on a Dell Mini 9 running Windows 7 Pro, 16GB SSD, 2GB RAM, and Tactrix 2.0 Rev C.
Thanks.
Digitalfiend
Re: ECUFlash 1.43 beta ERR_TIMEOUT during test write
Postby Digitalfiend » Sun Aug 29, 2010 7:54 pm
I guess no one knows? Is Colby even still alive? :P
Digitalfiend
Postby radsdau » Mon Aug 30, 2010 3:49 pm
It depends on the ECU type you have. If it's EVO7/8/9 then no, you won't brick it. If it's EVOX or Subaru, then if a flash fail occurs, it's bad if you key off. If you do, it's game over (most likely)- ECU repair time. (and 'borrow someone else's car' time)
Leave the key on and retry flashing if it goes south. If it repeatedly fails, check the connections are ok, and perhaps check what else is running on your laptop etc.
Postby Digitalfiend » Mon Aug 30, 2010 9:10 pm
Sorry, forgot that this isn't a Subaru-specific forum. I have an 08 STI and 09 WRX. So it sounds like as long as I don't turn off the ignition, there is a chance the loader can still allow a second (or third) reflash attempt.
Thanks.
Digitalfiend
Postby radsdau » Tue Aug 31, 2010 3:04 pm
You got it. No probs.
Return to OpenECU Software
