Page 4 of 7
PostPosted: Sun Apr 30, 2006 9:27 am
by cboles
[update] - The problem is fixed. There is a new 1.24 version on the site now.
I have a repro - thanks for the info. I've never seen that before. I'll check that out.
JRSCCivic98 wrote:I just duplicated that error. It only happens if you open 2 or more ROMs and close them in the reverse order that you opened them. For example, if you open ROM1 and ROM2 and then close ROM2 and then close ROM1 it will not error, but if you open ROM1 and ROM2 and then close ROM1 and then close ROM2 it will error out.
To add to this, it seems that if you open more then 2 ROMs it becomes evident that if you close them in any order other then the order you opened them in you will get an error. You can close 1 ROM file, but if it's out of order then very next one you try and close will generate the error message.
PostPosted: Mon May 01, 2006 9:34 am
by WolfPlayer
Curious,
Everytime I try to unzip the new 1.24 using WinRAR I get ...
1 ecuflash_setup124.rar: File "ecuflash_setup124.exe" header broken
2 ecuflash_setup124.rar: Unknown method in ecuflash_setup124.exe
3 ecuflash_setup124.rar: No files to extract
4 Cannot execute "ecuflash_setup124.exe"
t
PostPosted: Mon May 01, 2006 9:57 am
by cboles
I just downloaded it from the site (via the LAN). It seems to work for me.
PostPosted: Mon May 01, 2006 10:40 am
by twg
it extracts fine for me too.. try a newer version of Winzip
PostPosted: Mon May 01, 2006 11:08 am
by akcel
worked for me perfectly. just got my cable over the weekend ;) the fun begins
PostPosted: Mon May 01, 2006 11:57 am
by Freon
Here is a mirror of the .EXE. Might be worth a shot, but I had no problem with that RAR file either.
http://freon.shackspace.com/car/ecu%20a ... tup124.exe
PostPosted: Tue May 09, 2006 6:47 pm
by Rainmanjam
My ECU came up as a A2ZJ710J (AJ243 in ECUExplorer). This is the update that has the Ping fix in it but it is not listed in ECUFlash. Is there anything that I Can do to add this to the list?
PostPosted: Tue May 09, 2006 6:58 pm
by cboles
Yes - if you have an openport 1.2 or 1.3M cable, you can download EcuFlash from openecu.org, and read your ROM out, then post it here. EcuFlash will prompt you about not recognizing the ROM - choose to copy the ROM info from a similar ROM in the dialog in order to be able to get past that dialog and save the file.
PostPosted: Wed May 10, 2006 7:11 am
by Rainmanjam
All done.. Thanks.
04STI_A2ZJ710J_AJ243.bin
PostPosted: Wed May 10, 2006 7:18 pm
by Rainmanjam
PostPosted: Thu May 11, 2006 10:00 am
by Rainmanjam
Is there anything that I can use to edit this file?
PostPosted: Thu May 11, 2006 10:42 am
by Freon
Yes, ecuedit will. The offsets for most of the importa maps have been posted. You won't be able to see the axis labels, but all the data can be manipulated
XMLs need to be created.
PostPosted: Sat May 13, 2006 1:31 am
by Keiran
just got the cable today..
1st attempts are failures..
it said "no response to any known codes"??
whats up??
while it was "sending bit (0001)" the CEL appear.. and you can hear a relay click.. then "sending bit (ffff)" then tge failed connections
any help please?? btw its a jdm 7
editted : just opened up theecu.. it says MH8305 .. different from whats being quoted.. can that be theproblem??
Resize windows
PostPosted: Mon May 15, 2006 5:08 am
by New2Scoobs
I cant resize map windows in ECUFLASH. Am I missing a DLL or something?
Tried uninstalling and then reinstalling but still cant resize.
Re: Resize windows
PostPosted: Mon May 15, 2006 7:02 am
by cboles
This problem is coming from XMLWRITE, or whomever made the definition for the map you are looking at. There is a min and max value for the scalings you are using, and EcuFlash looks at those values to decide how big the text can possibly be, and sizes the cells accordingly. If you have unrealistic min/max values, you will get this problem. You can change them by editing the scaling in the map definition.
New2Scoobs wrote:I cant resize map windows in ECUFLASH. Am I missing a DLL or something?
