by bmw5002 » Mon Jul 21, 2008 11:12 pm
Attempting to flash an 05 wrx, with v1.33 on os x. Any ideas on what is wrong?
- Code: Select all
[02:47:46.656] Version 1.33.1428
[02:47:46.703] 11 memory models read.
[02:47:46.704] scanning for metadata models in /Applications/ecuflash.app/Contents/Resources/rommetadata
[02:47:47.123] 217 ROM metadata models scanned.
[02:47:47.123] checksum module "subarudbw" loaded.
[02:47:47.124] flashing tool "wrx02" loaded.
[02:47:47.124] flashing tool "wrx04" loaded.
[02:47:47.124] flashing tool "sti04" loaded.
[02:47:47.124] flashing tool "sti05" loaded.
[02:47:47.124] flashing tool "mitsukernel" loaded.
[02:47:47.124] flashing tool "mitsukernelocp" loaded.
[02:47:47.124] flashing tool "shbootmode" loaded.
[02:47:54.515] A4TF800F (278 tables) inheriting 16BITBASE (404 tables)
[02:47:54.533] A4TF800E (10 tables) inheriting A4TF800F (404 tables)
[02:47:54.564] 163840 byte image read.
[02:48:07.087] Using interface OpenPort 1.3 Universal TX45*izL2859b7c9118c2abbe259df261abea5acd6491085
[02:48:17.990] SSM2 init
[02:48:18.180] SSM2 ECU ID is 3E 14 44 40 06
[02:48:18.307] Requesting Seed...
[02:48:18.366] Sending Key...
[02:48:19.550] writing kernel area addr: 020000 len: 0664
[02:48:19.750] SSM2 write kernel ram block addr: 020000 len: 0080
[02:48:20.067] SSM2 write kernel ram block addr: 020080 len: 0080
[02:48:20.375] SSM2 write kernel ram block addr: 020100 len: 0080
[02:48:20.693] SSM2 write kernel ram block addr: 020180 len: 0080
[02:48:21.011] SSM2 write kernel ram block addr: 020200 len: 0080
[02:48:21.319] SSM2 write kernel ram block addr: 020280 len: 0080
[02:48:21.637] SSM2 write kernel ram block addr: 020300 len: 0080
[02:48:21.955] SSM2 write kernel ram block addr: 020380 len: 0080
[02:48:22.283] SSM2 write kernel ram block addr: 020400 len: 0080
[02:48:22.600] SSM2 write kernel ram block addr: 020480 len: 0080
[02:48:22.918] SSM2 write kernel ram block addr: 020500 len: 0080
[02:48:23.236] SSM2 write kernel ram block addr: 020580 len: 0080
[02:48:23.554] SSM2 write kernel ram block addr: 020600 len: 0064
[02:48:24.078] kernel get version
[02:48:24.109] kernel version is : OpenECU Subaru HC16 Kernel V1.05
[02:48:24.109] reading kernel comm buffer size
[02:48:24.130] comm buffer size set to 512
[02:48:24.130] reading kernel flash buffer size
[02:48:24.141] flash buffer size set to 4096
[02:48:24.141] Flashing image to ECU memory...
[02:48:24.541] comparing ECU flash memory pages to image file
[02:48:24.541] seg start len ecu CRC32 img CRC32 same?
[02:48:24.884] FB01 00000000 00004000 8DF26C32 8DF26C32 YES
[02:48:25.217] FB02 00004000 00004000 257C9BAA 257C9BAA YES
[02:48:25.550] FB03 00008000 00004000 9576D9EA 9576D9EA YES
[02:48:25.883] FB04 0000C000 00004000 98DCDDB3 98DCDDB3 YES
[02:48:26.206] FB05 00010000 00004000 BE7614A2 BE7614A2 YES
[02:48:26.539] FB06 00014000 00004000 9655B910 9655B910 YES
[02:48:26.862] FB07 00018000 00004000 E540EA54 E540EA54 YES
[02:48:27.195] FB08 0001C000 00004000 4E5C83CD 4E5C83CD YES
[02:48:27.518] FB09 00028000 00004000 8C55000E E8E99E41 NO
[02:48:27.851] FB10 0002C000 00004000 F5CAC112 F5CAC112 YES
[02:48:28.152] reading ecu programming voltage
[02:48:28.173] programming voltage is 12.05 volts
[02:48:28.173] kernel flash enable
[02:48:28.194] rkrv: can't read response payload
[02:48:28.194] interface close
[02:48:28.204] interface close
bmw5002
Return to OpenECU Software
