"Incorrect file size"
Postby Zand » Mon Jun 02, 2008 1:41 pm
Hello, I just bought the XPT stage 2 WRX MT map, and downloaded it and I am trying to load it to EcuFlash and I am getting the error "Incorrect file size" whenever I try to open it with ecuflash. This is my first time flashing with this style of software(attempting to convert from accessport, if I can get this to work) I went through the romraiders getting started FAQ made sure I had everything there correct.
Hoping this is just a noob question, thanks for reading :)
Zand
Postby radsdau » Mon Jun 02, 2008 3:11 pm
A few more details would be helpful. What car do you have? What is the ROM filename? What is the ROM ID? How big is the file? Which version of ECUFlash are you running?
Postby Freon » Mon Jun 02, 2008 8:11 pm
ECUflash won't let you try to flash a file that is the wrong size. You should ask XPT for help, it is a problem with the file.
Postby radsdau » Mon Jun 02, 2008 11:10 pm
Freon wrote:ECUflash won't let you try to flash a file that is the wrong size. You should ask XPT for help, it is a problem with the file.
Yes, do that first...!
Return to OpenECU Software
