EcuFlash V1.35 Crashes on ROM Read
Postby Mattjin » Sun May 18, 2008 1:39 am
Just installed V1.35 (on Vista Business machine) and it refuses to do a ROM Read. It goes past the point where you select vehicle type, then it locks up not respsonding. Re-installed V1.34 and all is working perfectly.
Anyone else having any problems?
Mattjin
Re: EcuFlash V1.35 Crashes on ROM Read
Postby BoxerFan » Tue May 20, 2008 7:27 am
If it is 100% CPU hang, I have the same problem.
BoxerFan
Postby evo400 » Tue May 20, 2008 12:11 pm
Me too on WinXP
100procent CPU load :roll:
evo400
Postby Jon [in CT] » Tue May 20, 2008 5:33 pm
I think you need to explain exactly what you were attempting to do and exactly how far the program got while doing it.
Postby blue.taxi » Tue May 20, 2008 8:01 pm
btw, should the released date is 2008?? or is it a back dated ver?
http://www.openecu.org/index.php?title=EcuFlash
blue.taxi
Postby evo400 » Tue May 20, 2008 9:18 pm
Jon [in CT] wrote:I think you need to explain exactly what you were attempting to do and exactly how far the program got while doing it.
OK, if you run program, than select car to dowload rom and it hangs after that. U see only 100% CPU load on system and no comunication with cars ecu. Using 1.3M cable
evo400
Postby BoxerFan » Wed May 21, 2008 1:27 am
evo400 wrote:OK, if you run program, than select car to dowload rom and it hangs after that. U see only 100% CPU load on system and no comunication with cars ecu. Using 1.3M cable
Exactly the same symptom. Also using 1.3M cable, to read Subaru 32bit ECU.
-> 1.3M cable to read/flash Subaru 32bit works with 1.29.
BoxerFan
Postby Mattjin » Thu May 22, 2008 2:08 pm
I was trying to read an EVO 7, but it is definitely repeatable.
Exactly what I did. Got the notice in V1.34 that V1.35 is released. Downloaded and installed, but then find the crashing problem. It recognises the cable is there, it lets you select to do a ROM read, you select the vehicle type, then it hangs. Never noticed the CPU usage sorry.
Re-install V1.34 and back to fully operating again.
On a side note for whoever is reading this and has something to do with the software developement. Is it possible to add something to the software to remember where each map is placed on the screen? It remembers while the software is open and each map is opened and closed, but restart the software and you have to go back to re-positioning mulitple maps so you can see them. Minor annoyance.
Mattjin
Return to OpenECU Software
