Ecutek lock out..
ECU unresponsive
Postby renhoek » Fri Mar 28, 2008 2:44 pm
Hi. Wondering if you can help me out of this jam. I've been using Ecuflash to flash the ECU in my bugeye rex. Done about 50 so far. Today it failed. :cry:
Here is the log...
[00:35:21.170] reading ecu programming voltage
[00:35:21.190] programming voltage is 11.99 volts
[00:35:21.190] kernel flash enable
[00:35:21.410] kernel blank flash page: addr: 00028000
[00:35:21.660] erased in 1 pulse(s)
[00:35:21.710] kernel write flash buffer addr: 00028000 len: 00000200
[00:35:21.861] kernel write flash buffer addr: 00028200 len: 00000200
[00:35:22.031] kernel write flash buffer addr: 00028400 len: 00000200
[00:35:22.201] kernel write flash buffer addr: 00028600 len: 00000200
[00:35:22.572] kernel write flash buffer addr: 00028800 len: 00000200
[00:35:22.742] kernel write flash buffer addr: 00028A00 len: 00000200
[00:35:22.892] kernel write flash buffer addr: 00028C00 len: 00000200
[00:35:23.052] kernel write flash buffer addr: 00028E00 len: 00000200
[00:35:23.413] kernel commit flash addr: 00028000 crc32 d53f9b5a
[00:35:23.813] written in 1 pulse(s)
[00:35:23.823] kernel write flash buffer addr: 00029000 len: 00000200
[00:35:23.984] kernel write flash buffer addr: 00029200 len: 00000200
[00:35:24.144] kernel write flash buffer addr: 00029400 len: 00000200
[00:35:26.818] readback fail
[00:35:26.828] WARNING: failure in flashing block
[00:35:26.828] kernel write flash buffer addr: 0002A000 len: 00000200
[00:35:26.948] readback mismatch
[00:35:26.958] WARNING: failure in flashing block
[00:35:26.968] kernel write flash buffer addr: 0002B000 len: 00000200
[00:35:27.078] readback mismatch
[00:35:27.098] WARNING: failure in flashing block
[00:35:27.098] kernel flash disable
[00:35:27.098] readback mismatch
[00:35:27.098] verifying result...
[00:35:27.098] comparing ECU flash memory pages to image file
[00:35:27.098] segment len ecu CRC32 img CRC32 same?
[00:35:27.098] error reading CRC!
[00:35:27.098] error verify checksums! exiting.
Car cranks but no start.
I'm in Albury NSW. Anything you can do to help?
cheers mate
renhoek
Postby LOK11 » Fri Mar 28, 2008 9:55 pm
Don't think I can help without the ECU here, if you don't find a solution by Monday send us the ECU and we should be able to recover it for you.
Cheers
Lachlan Riddel
Technical Director
ChipTorque
LOK11
Postby renhoek » Sat Mar 29, 2008 12:36 am
Thanks Lachlan. I disconnected the battery another time, and this time I waited 20 minutes (only waited about 5 minutes the first time). Reconnected the battery and tried re-flashing again.
As the program was reflashing, just the progress bar cycled across the screen - twice. No fresh log was generated for the flash.
Tried to start and it WORKED! :shock: Car starts now.
I have no idea why it worked, or why it failed in the first place, but it's good to know that you guys could potentially fix a bad flash to the ECU.
Please advise your contact details so I can have them to hand, as it will probably go bad on me again one day.
To be honest, I'm getting a little nervous with this flashing business now! :)
cheers
renhoek
More fallout from the failed flash?
Postby renhoek » Sat Mar 29, 2008 6:11 pm
Couldn't start the car today. Seems it is not acceptiong the immobiliser code. It's as if I'm using the wrong code. Maybe the failed flash corrupted the immobiliser code?
I'll call the local dealer tomorrow to see if they can re-input the code. If I have any dramas there, looks like I'll get to meet you sooner than I thought! :roll:
renhoek
Return to OpenECU Software
