New GUI version of EcuFlash
Postby cboles » Mon Nov 14, 2005 2:16 pm
download the new 1.01 version. it should fix your problem
Postby Jeramie » Mon Nov 14, 2005 2:17 pm
"I'm testing a fix right now. Basically, a signal should be turned on before the instructional dialog you see at the start of the operation."
Now thats service!! Colby is the man!
8)
Jeramie
Postby NeverLies » Tue Nov 15, 2005 1:39 am
Will test it and let you know.
Postby enash » Wed Nov 16, 2005 8:32 am
i am getting that same error "The procedure entry point could not be located in the MSVCR71.dll" I removed from app dir and tried to run which didnt work. Moved them to system dir didnt work either. ideas?
enash
Postby NeverLies » Wed Nov 16, 2005 12:39 pm
Which OS are u running ?
Postby cboles » Wed Nov 16, 2005 12:59 pm
When you right-click the DLLs, what are the version numbers?
Postby Spiider » Wed Nov 16, 2005 2:34 pm
You shouldn't have moved them, just delete them from the app directory.
Postby wall of tvs » Fri Nov 25, 2005 11:00 pm
enash wrote:i am getting that same error "The procedure entry point could not be located in the MSVCR71.dll" I removed from app dir and tried to run which didnt work. Moved them to system dir didnt work either. ideas?
I'm having the same problem. Deleting the DLLs didn't work.
Running Win2k Pro.
wall of tvs
Postby Spiider » Sat Nov 26, 2005 4:48 am
Oh, Win2k may need a copy of the working XP dll's.
Maybe you can google those versions or someone can post them up here.
I can dig them up and post them if you give me the names of both again.
Postby ghostwrx » Sat Nov 26, 2005 8:29 am
I have tried to get this to run and I am getting "This applicantion has failed to start because MSVCR71.dll was not found. Re-installing the application may fix this problem." now i have doenloaded the proper .dll file and put it into the ecuflash file and got the same message. I am running XP Pro, I tried putting it in the system file and got the same result, am I not doing something right? This seems pretty straight forward to me, but I am still learning.
ghostwrx
Postby Freon » Mon Nov 28, 2005 4:14 pm
I run windows 2000 and was able to get it to run by downloading the DLL files from dll-files.com and putting them in the /ecuflash install directory.
It only lists the WRX, though. I would like to download this and share my 2004 USDM STI rom file.
Postby NeverLies » Tue Nov 29, 2005 4:04 am
It manages standard WRX and also STI ;) Let's have a try, it works perfeclty on mine. STI has the same management as standard WRX.
Postby Freon » Tue Nov 29, 2005 7:29 am
Gotcha, I'll give it a try and see if it will pull my ROM down.
Post your ROM!
Postby Jeramie » Tue Nov 29, 2005 7:44 am
Colby,
Finally got a chance to use the GUI and works great. Thanks for all the hard work.
Have you ever thought about adding a button that test flashes and if the test is all good continues with the real flash? Just and idea since I test every image before I flash. Thanks
Jeramie
Postby cboles » Tue Nov 29, 2005 8:01 am
Sure - I could do that...
Return to OpenECU Software
