OpenPort 1.3M Schematic
Postby cboles » Tue Nov 14, 2006 5:52 pm
Correct!
Re: Here is the schematic
Postby autozoom42 » Mon Dec 11, 2006 9:57 pm
cboles wrote:Here is the schematic. This is for a version that I have yet to make that includes voltage regulator for reflashing WRXs. You can omit this and it is basically the Mitsubishi version of the design.
Hi,
I am a new baby in this forum. Please advise where I can find the schematic :)
autozoom42
Postby Rotawerx » Tue Dec 12, 2006 12:41 am
On the first page f this thread. Should show up after a day or so I think of joining.
Rotawerx
Postby STAT » Tue May 08, 2007 9:59 am
I breadboarded out the circuit posted earlier in the thread. Things aren't working perfectly yet and I have a few questions.
What is the BOOT pin for?
I am working with a 2007 WRX, I am assuming no difference between the 2006 and 2007 models.
I have tried both enginuity and openecu with no luck. Neither piece of software can read the rom image. (Enginuity can't start logging)
I haven't ruled out a driver issue yet with the computer I'm using. I'll get the most recent ftdi drivers from their website and give it another shot.
Thanks for any advice
STAT
Postby gotcha » Tue Oct 16, 2007 2:44 am
is there any sch available which uses a ft232BM ?
gotcha
Postby DJesco » Wed Feb 06, 2008 1:41 pm
Can someone be kind enough to email me the schematic. I cant download the file even though I am using acrobat reader. djesco@hotmail.com thanks
DJesco
Postby Freon » Wed Feb 06, 2008 2:59 pm
It downloads fine for me. I mirrored it here:
http://freon.shackspace.com/car/ecu%20a ... port13.pdf
Postby mick711 » Fri Mar 28, 2008 1:02 pm
Hello
Do you know what other composant it's possible ?
Because i can't find all in the same office i find few on this site :
http://radiospares-fr.rs-online.com/web/home.html
or
https://www.distrelec.ch/ishop/StaticHT ... distrelec/
So what it's possible other :
L4931ABD120
SN74HC257D
FT232RQ
LM555CM
D1 BAV99
SD601
I'm if you don't see :lol: a newbi
I know other shop but few componant don't exist ! Do you know a web site where i can buy all or other componant ?
Escuse for my bad english i'm french :lol:
mick711
Postby Jon [in CT] » Fri Mar 28, 2008 7:38 pm
mick711 wrote:I know other shop but few componant don't exist ! Do you know a web site where i can buy all or other componant ?
Try http://www.digikey.com/.
Postby mick711 » Sat Mar 29, 2008 9:59 am
But like i say :
L4931ABD120 not in stock :?
So i think i can't find all in the same shop :( do you have any solution ?
It's for that i write if it's possible to put an other componant .
or if you can go to this web site and find reference that it's good for i can buy
:oops:
mick711
Postby Jon [in CT] » Sun Mar 30, 2008 12:11 pm
Digikey, at this moment, shows it has 560 in stock of the L4931ABD120 (see http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=497-1153-1-ND).
Digikey part number 497-1153-1-ND is L4931ABD120.
Do not worry that part S5800-05-ND is described as "valeur ajoutée" with 0 in stock at Digikey. Read the explanation for that at http://dkc1.digikey.com/FR/FR/HELP/help07.html.
Postby mick711 » Mon Mar 31, 2008 3:01 am
So i find a friend to help me for make the openport because i'm a very big newbi and i think i don't buy the good parts like sd601 , resistor etc. i don't know :(
mick711
Re: OpenPort 1.3M Schematic
Postby lathiat » Sat Jun 30, 2012 6:35 am
To save everyone else the headache and heartache of the last few days.. the OpenPort 1.3D as sold by EvoScan.com does not follow this schematic, the RTS line does not flip DTR to drive the Kline.
Finally succeeded in initing the ECU by using FTDI bitbang mode to directly drive the TX pin. Timing that works (possibly not quite right... who knows) is:
300ms low
2800ms high
1818ms low
high
<change out of bitbang and into 15625 baud> and expect C0 55 EF 85 although I haven't managed to receive the C0 yet the FTDI always misses it.. not sure if syncing up or timing.. but I get the 55 EF 85 quite reliably.
lathiat
Postby masterg » Tue Jul 31, 2012 4:10 pm
What does the BOOT line connect to? its just hanging off the 555 timer not connected to anything else. I don't want to make a board for it and have to fix one line, or find out it doesn't work
masterg
Postby Hexec » Fri Sep 14, 2012 5:20 pm
So the schematics on the first page is for the 1.3U. What has changed in 1.3U to become OpenPort 2.0? Is the 2.0 schematics available also?
Hexec
Return to OpenECU Hardware
