wrx 09 reflash
wrx 09 reflash
Postby andythierry » Sun Nov 15, 2009 8:04 pm
I had problem with reflashing an STI 01 with my open port 2.0(the flash fails an the car wont start) then i put my open port 1.2 in the car and recover the ecu.I think it was because my computer was on xp SP2 instead of SP3.
Now i want to reflash an WRX 09 but it 'll be the first time i reflash a car without flash block.
Does someone did it ? it is as simple as : put the plug in the car an press reflash or there is something i must know?
andythierry
Re: wrx 09 reflash
Postby poohbear » Fri Feb 18, 2011 7:31 am
08+ use CANbus and there is no need to attach any reflash connectors... The open port 2.0 cable puts the ecu into test mode automagicly for you...
poohbear
Return to OpenECU Hardware
