Here are the drivers for OpenPort 1.0
Postby ahains » Wed Oct 12, 2005 9:15 am
I had to search around a little while on the site to find them, so I thought I would make an easy to spot thread in obvious forum for future folks looking for them :)
This is the page that has the driver downloads, so this is where you should go to download it:
http://www.ftdichip.com/Drivers/FT232-FT245Drivers.htm
If for some reason that page ever disappears, I have archived a snapshot of all of the current drivers available from that page. I'm attaching that to this post. Note that you should use the above link if it available, as that will get you the LATEST drivers which could potentially contain bug fixes. This zip file is only in place as a back up plan :)
-Adrian
OpenPortDrivers.zip
Back up archive of drivers for OpenPort cable. Use the direct link to ftichip.com instead if it is available.
(1.28 MiB) Downloaded 900 times
ahains
Return to OpenECU Hardware
