VAG-COM compartibility
Postby Mick » Mon Oct 16, 2006 3:45 am
Not important.
I have a GC8 but i tested vag-com 3.11 with the openport 1.2 on many vag-group cars and the cable and it work's fine.
Mick
newbie question
Postby patpat » Mon Feb 26, 2007 6:14 pm
Can I use a Vag-Com 409 cable with the OpenPort 1.3 ActiveX Control?
thanks
Pat
patpat
Re: newbie question
Postby xor » Tue Feb 27, 2007 4:21 am
patpat wrote:Can I use a Vag-Com 409 cable with the OpenPort 1.3 ActiveX Control?
thanks
Pat
Do you mean Cabletools? I tried with my Vag-com interface and it does not work, because it has different idientifier in the ftdi232 eprom. Cabletools looks for an Openport string (don't remember exactly), but my interface's identifier is something like "usb dual kkline".
xor
Postby patpat » Tue Feb 27, 2007 7:21 am
I have a vag-com 409 "compatible" cable (FT232BM based) and I'd like to use the OpenPort ActiveX control with it.
if the problem is just the ftdi232 expected identifier I think that is very easy to solve...
I'd like to hear experiences on this I don't want to re-invent the wheel...
Pat
patpat
Postby S54fan » Tue Feb 27, 2007 12:28 pm
Which download of Vag Com works with the Openport cable?
My wife has a Golf GTI 2.0T.
http://www.ross-tech.com/vag-com/download/
Postby xor » Tue Feb 27, 2007 1:35 pm
S54fan wrote:Which download of Vag Com works with the Openport cable?
Openport will work with VAG-COM 3.xx & VCP drivers. Check also this site http://www.hackersrussia.ru/Cells/OBD2/
xor
Return to OpenECU Hardware
