Help Diagnostic port wiring
Postby chrispol3 » Tue Aug 29, 2006 7:14 am
Ok had an engine swap everything seems fine 98 legacy gt to 04 wrx 2.0t engine / drivetrain and ecu ... but i cannot access the ecu via the diagnostic port with my tactrix cable.. i'm guessing wither the diag port was not hooked up, anyone have any info on what wires from the ecu go to the diag port on a 04 wrx? or can i just pin directly from the ecu?
Any Help would be great, ideally i would like to direct wire it to the ecu
chrispol3
Postby m3n0ch3 » Tue Aug 29, 2006 7:31 am
m3n0ch3
Postby chrispol3 » Tue Aug 29, 2006 8:49 am
Yep i did, so if i
B135-14 is test mode when grounded
but what pins do i jump to the tactrix cable ??
chrispol3
Postby m3n0ch3 » Tue Aug 29, 2006 9:45 am
check the SSM pin...
B134 - 21 if I`m not wrong
m3n0ch3
Postby chrispol3 » Tue Aug 29, 2006 10:24 am
So...
Test mode connector B134-14
SSM/GST communication B134-21 -> pin 7 k-line
Line End Check B134-10 -> pin 11 flash voltage
B134-20 -> OBD pin 9 is the L-Line
patched this from ecu bench thread http://forums.openecu.org/viewtopic.php ... light=b134
but B134-20 does not seem to be listed in 04 sheet......
B134-14 has to be grounded when? only on flashing?
also there are 6 pins on the tactix cable?
chrispol3
Postby chrispol3 » Tue Aug 29, 2006 10:54 am
Ok i think i got it
Tactix Cable Pin 16 -> +12v
Tactrix Cable Pin 4+5 -> Gnd
Tactrix Cable Pin 7 -> K-Line SSM/GST communication B134-21
Tactrix Cable Pin 11 -> Line End Check B134-10
B135-14 Grounded when flashing
Can anyone confirm is this is the right hookup?
chrispol3
Postby chrispol3 » Tue Aug 29, 2006 11:58 am
Yay it works, Holy trouble codes batman .....
chrispol3
Postby chrispol3 » Fri Sep 08, 2006 8:08 am
Now .. for the flash connectors my wiring harness is from a 98 legacy so can i use the flash connectors or do i have to wire from the ecu ? what wires need to be jumped from the ecu??
chrispol3
Users browsing this forum: No registered users and 33 guests
