Ok, I've got an 05 sti, so either cable will work if I'm reading the tables correctly. Am I correct that the trade off is basically 1.2 for better subaru support, or 1.3m for only 32bit subaru support but also mitsubishi support?
thanks,
greg
JRSCCivic98 wrote:Yes, if you have no need to flash WRXs then the 1.3 may be a better cable for you, but only if you plan on working with EVOs as well. I think sometime in the future Colby will make some new software changes that will allow the 1.3 to work with WRXs as well. At least this is what he's said.
gregsachs wrote:will the 1.3m cable work for _reading_ all subaru versions?
cboles wrote:There is no software change that will make a 1.3M work with a WRX. The 1.3M has special hardware to work with the Mitsubishi (a switchable 16V source), the 1.2 has special hardware to work with the WRX (a switchable 12 regulated source). The Subaru DBW ECUs require neither of these signals, and so they will work with both.
Users browsing this forum: No registered users and 38 guests
