Openport2.0 pin 11
Openport2.0 pin 11
Postby salt36 » Sat Dec 31, 2011 10:51 pm
OK a brief description, 2009 AUDM Mitsubishi Triton 3.5L 6G74 V6, ECU: M32r Renasis processor, 32176F4 Family.
I would like to know if it possible for the init code to run direct to pin 11.
I can read/flash my ECU on the bench using the Mitsu init plug running to pin 83 I think from memory on the ECU, this pin runs to pin 11 on the OBD.
Is there a way I can configure this ?
I would also like to be able to reverse this if the occasion demanded......
salt36
Re: Openport2.0 pin 11
Postby salt36 » Fri Jan 06, 2012 1:47 am
I sorted it 8)
salt36
Postby radsdau » Sun Jan 08, 2012 4:28 pm
Good to hear. Care to share your solution with us?
Postby salt36 » Tue Feb 28, 2012 2:18 am
Whoops havent logged on for ages...... :oops:
I am going to use (whenever it arrives :roll: ) an OBD extension cable and splice the init wire into the pin 11 on the vehicle side of the extension cable.
I am hoping this will work and wont have to remove the ECU each time I want to flash..........
salt36
Users browsing this forum: Bing [Bot] and 5 guests
