HELP!! 1.3u connecting problem
Postby raza21_84 » Thu Aug 18, 2011 9:03 am
Hello people I have a 1.3u cable for my evo 7.
The problem is I have a old laptop running windows 7 64bit. All drivers for that laptop gets downloaded form the internet by the way.
Now the cable works perfectly fine on this laptop.
I recently bought a netbook. (novatech N1). For some reason Evoscan or ECUflash dont pick up my cable. When the cable is connected Evoscan picks up something under (logging tab) but it don't show 1.3u openport with a tick on the side, It just shows up Blank and a tick next to it. My old laptop does show this.
I am running windows 7 32bit on the netbook as the driver disk I have with the netbook only supports 32bit windows.
I will have to look around in the mean time if I can find 64bit supported drivers for the netbook so I can change to 64bit OS. If that is causing the problem. Otherwise can someone please confirm that they have it working on a windows 7 32bit, then that problem will be eliminated form the problem list.
The cable on my netbook does show up as 1.3u openport Under device manager. So the computer picks it up but Evoscan does not. All the settings and program files/folders I have been compared between both computers and all seems good.
Need some light on this. Has anyone tried this successfully on windows 7 32bit? Is their a glitch or some sort I need to know with the programs?
raza21_84
Re: HELP!! 1.3u connecting problem
Postby raza21_84 » Fri Aug 19, 2011 8:58 am
Anyone!!!!!
Isn't their anyone running EVOscan and ECUflash succesfully in windows 7 32bit OS?????
raza21_84
Postby raza21_84 » Sun Aug 21, 2011 1:11 pm
Helooooooo
raza21_84
Postby radsdau » Sun Aug 21, 2011 4:23 pm
ECUFlash- yes, works. Evoscan- I don't know, but I can't see why not.
Postby raza21_84 » Tue Aug 23, 2011 3:17 pm
Hi radsdau. Can you give me a little spec about your laptop or netbook please
raza21_84
Postby radsdau » Wed Aug 24, 2011 4:50 pm
Lenovo T60. It has had 23- and 64-bit Win7 on it; both fine.
Postby raza21_84 » Thu Aug 25, 2011 10:06 am
I found the fooking problem. The USB 3 driver. Left that out. Now everything works perfectly. Il wait till I actually have a proper usb 3 device and by then there should be a working driver out.
raza21_84
Postby radsdau » Thu Aug 25, 2011 3:39 pm
Nice find, thanks for letting us know.
Users browsing this forum: No registered users and 48 guests
