Error read EVO X
Error read EVO X
Postby soic8 » Mon Feb 14, 2011 1:06 am
Hello,
I have a problem with Evo X, i read this car and if I open original file I see this error “There was an error reading this ROM file. See the message log for details.”
I not find for plug the white connector on this car (it’s not same Evo 8 ).
Can you help me
evo X.bin
(1 MiB) Downloaded 855 times
error evo X.jpg (16.87 KiB) Viewed 6881 times
soic8
Re: Error read EVO X
Postby radsdau » Mon Feb 14, 2011 3:24 pm
This ROM is 53040007. You need an XML for this (search this forum).
Postby soic8 » Wed Feb 16, 2011 10:43 am
No my problem is for write.
If i select ori file, i have this error.
Do you have a good guide for read and write this car.
Do you think this error it's protocol ?
soic8
Postby And » Tue Apr 26, 2011 11:30 am
there is no flash onnector on the X's also alot of them have the ecu locked so you might not be able to write, have you managed to read it?
And
Postby radsdau » Wed Apr 27, 2011 9:34 pm
There was a post earlier about the latest ECUFlash Beta not handling files with a .bin extension. Try renaming it as .hex.
I can't confirm either way if it will fix anything but it's worth a shot.
Postby todd-w » Fri Apr 29, 2011 4:41 am
todd-w
